Bisimoto D16z6 700 WHP. Rural JDM!
  • Bisimoto D16z6 700 WHP. Rural JDM!
    Inspirado en el th de pucho cuarenti les dejo esto:
    El auto:
    El proyecto empeso en Octubre del 2009.
    Los """"BOLT ON""""
    Head:
    D16Z6 head (thanks, L&T)
    Bisimoto Cam Gear
    Bisimoto Springs and Titanium retainers
    Bisimoto Level 3.6 camshaft
    Supertech Stainless Steel intake valves
    Supertech Inconel Exhaust valves
    Golden Eagle Head gasket
    Block:
    D16Z6 (thanks Santos Jr.)
    Arias 9:1, 75.5mm pistons
    Golden eagle sleeves
    Bisimoto Spec H-beam steel Rods
    Honda Bearings
    Stock Ported Oil pump
    Bisimoto/Evolution Aluminum Flywheel
    Bisimoto/Evolution Sandwich plate
    AEM Oil Pressure gauge
    Hasport D-series Mounts
    Gearbox:
    Stock D15B Vtec (for now)
    Induction/Fuel:
    Bisimoto heat shielding gasket
    Golden Eagle Intake manifold
    Skunk 2 68mm throttle body
    T1 1000cc Injector dynamics squirters
    AEM Fuel rail
    AEM Fuel pressure regulator
    AEM fuel pressure gauge
    -6AN fuel lines
    Stock return lines
    AEM Water Meth kit (for super high boost!)
    Kinsler Monster Mesh fuel filter
    Turbo system:
    Bisimoto-Turbonetics BTX6565
    Bisimoto Prototype top mount twin scroll manifold, ceramic coated
    Turbonetics RG-45 wastegate
    Turbonetics Godzilla BOV
    3" Intercooler piping
    Turbonetics/Spearco 5-364 (3.5"x10.5"x28" wide..and yes, we made it fit!)
    -3an oil feed line
    -10an oil return
    Lubricants:
    Torco TBO 40 (break-in oil)
    Torco SR-1 racing 10w-40 (after break-in)
    Torco MPZ Spray assembly lube
    Torco MTF gear box oil
    Electronics:
    AEM 6040 Gen 2 EMS
    AEM UEGO
    AEM Twin fire
    AEM COP EPM
    AEM pencil Coils
    AEM Serial Gauge (this is so sick!)
    AEM boost control solenoid
    AEM 5 bar map sensor
    MSD digital Boost-a-pump pn 2351
    Power XS Battery
    Rywire mil-spec wiring
    Cooling:
    Custom dual pass Griffen radiator
    Buddy Club Radiator Cap
    Aesthetics:
    Bisimoto Adjustable Oil Cap
    Bisimoto Reservoir Socks
    Aca esta Terminado, muy linda la rural, bien limpia y al mejor estilo JDM:
    Videos quien me los arregla, y de paso me explica como:
    YouTube - Bisimoto 700whp D16 sohc wagon idle and 2-step.
    YouTube - Bisimoto 700whp D16 tuning session
    YouTube - Bisimoto 700whp D16Z 1990 Honda Civic Turbo Wagovan
    -480whp @19PSI, con nafta de surtidor de 91 octanos, equivalente a la Fangio 97 octanos nuestra + water/meth.
    -708whp @38/40psi con nafta de surtido de 91 octanos, equivalente a la Fangio 97 octanos nuestra + water/meth con signos de detonación en la porcelana de las bujías.
    -724whp con Torco unleaded de 108 octanos
    ---------- Post added at 09:33 ---------- Previous post was at 09:31 ----------
    Respuesta: Bisimoto D16z6 700 WHP. Rural JDM!
    Posta le sacaron 700+ a un D16?Mucha prolijidad!!!!
      mierda, agarran los motores mas "pedorros" o menos racing y desarrollados si se quiere (al menos en calle, el d16 corria en formula honda y otras :p) y supuestamente de calle sacan potencias descomunales... 510hp/litro !!! no sera mucho ??? jojo.. q locura
      igual el morocho traicionero tiene una remera de i love twin cams jaja
        Bici es un muy reconocido preparador de motores honda soch, un comentario decia algo asi "lo mejor que hizo el hombre despues de el combustible, son los motores soch"
          jajaj una bestiaaa
            [YOUTUBE]tGTWpP874yU[/YOUTUBE]
            [YOUTUBE]FIhA7_c_Yx0[/YOUTUBE]
            [YOUTUBE]NAl180zN3Z0[/YOUTUBE]
            Para poner los videos tenes que poner solo el código del video, el que esta después del com/watch?v= y antes del signo & (a veces el signo & no esta, en este caso solo pone lo que este después del watch?v=)
              q prolijidad la puta madre...y q de ponys q le sacan a esos motorcitos jeje
              una duda de burro nomas...para q son las muecas de los pistones?? para las valvulaS??
                me quiero volver chango!
                  peequeño caracol
                    La verdad que no suelo comentar en estos post porque no soy un seguidor de los coches asiaticos. Pero me gustaria saber si verdaderamente este motor puede desarrollar 700 HP? o es un fake o como quieran llamarlo. Que cilindrada es?
                      1.6 16v.
                      ---------- Post added at 18:15 ---------- Previous post was at 18:14 ----------
                      creo q las muecas es donde pulveriza el inyector.
                        bisimoto tieen un civic soch (1.6 litros)aspirado que mete 9.50 segundos en 1/4 de milla ,terrible y en la parte turbo los hondas andan muy bienn como este celestitoo
                        YouTube - 8 sec. Civic
                          Muy lindo. Y la muesca de los pistones es para las valvulas.
                          Ahora, de que mierda son los pistones? :| son color cobre jeje
                            Ideal para ir de pesca con la familia!!! jajaja
                              acabo de ver los videoos
                              mmmmmmamadera como anda eso
                              ---------- Post added at 23:43 ---------- Previous post was at 23:43 ----------
