PLYMOUTH BARRACUDA 69" CAR IN BLACK!
  • PLYMOUTH BARRACUDA 69" CAR IN BLACK!
    ENGINE
    Type: Chrysler 394, LA Series small-block
    Block: Chrysler, bored to 4.070 inches
    Oiling: Stephs
    Rotating assembly: Callies 3.790-inch crank and Eagles H-beam steel rods; forged 11:1 CP pistons
    Cylinder heads: ported Edelbrock Performer RPM aluminum castings with Manley SS severe duty valves
    Camshaft: COMP 260-at-.050 solid, flat-tappet roller, .586-inch lift
    Valvetrain: COMP Pro Magnum roller rockers; COMP beehive valvesprings, Manton pushrods
    Induction: Edelbrock Super Victor manifold, PC-built Holley 750-cfm carburettor
    Exhaust: TTI headers
    Power adder: n/a
    Fuel system: electric fuel pump, regulator mounted at the carb
    Ignition: MSD Digital 6 ignition system
    Cooling: Howe radiator, Meizere electric pump, electric fan
    Output: estimated 560 hp
    Built by: Sloan Racing; machine work by Dougans
    DRIVETRAIN
    Transmission: Chrysler 904 built by Pro Trans, 10-inch Turbo Action 3,500-rpm torque converter and Precision Performance Products shifter
    Rear axle: Chrysler 9 3/4 with 4.30:1 gears, Richmond Spool
    CHASSIS
    Front suspension: Firm Feel upper tubular control arms, Mopar drag torsion bars, QA1 adjustable shock absorbers, '73 Chrysler spindles
    Rear suspension: Calvert split monoleaf springs, CalTracs traction bars, RS9000 adjustable shock absorbers
    Brakes: Wilwood front disc brakes and factory Chrysler rear drum brakes
    WHEELS & TIRES
    Wheels: Weld Racing 15x3.5, front; 15x8, rear
    Tires: Mickey Thompson 26x7.5x15, front; Mickey Thompson P275/60R15 ET Street Radial, rear
    Respuesta: PLYMOUTH BARRACUDA 69" CAR IN BLACK!
    jojoooooooo hermosooo!!!...
    que lindo autoo dios mioo
      Simplemente hermoso!!!
      Es vin diesel el que maneja jajajjaja
        pensar q tengo un amigo q tiene uno tirado en el fondo de la casa re pudriendose mal!!
          perfecto,muy dentro de lo original...quiero uno...
            jaja mui lindo autoooooo x dioooooss
              Q belleza!!!!!
                direccion y telefono?
                  hace 5 años q le estoy insistiendo en q me lo venda y no afloja y si algun dia lo vende va a ser mio
                    q año es y q motor sabes?
                      no recuerdo si 68 o 69, lo q tambien se es q los trajo roberto mouras a la argentina para correr picadas, se trajo dos y un casco de repuestos, uno esta en mardel y otro aca en la plata, despues el casco lo robaron de un galpon y supuestamente lo estaban usando con un motor de chevy!!
                        Che eso es increible, loco postea foto y decile a tu amigo que lo large si no le va adar vida
                          q pena! una q lo dejen pudrir, y otra pena q tenga motor chevrolet...
                          gracias por responder.
                          suerte
