Para los que les gusta las motos Ducati 749r 2005
Les dejo 2 fotos que saco LDIBLAS ................... :mrgreen:
The 2005 Ducati 749r engine has been specially developed for efficiency on the track. It develops 121 hp at 10,500 rpm and 8.6 kgm of torque at 8,250 rpm
Frame Tubular ALS450 steel trellis
Wheelbase 1420 mm / 55.9 in
Rake 23.5°÷24.5°
Front suspension Öhlins upside-down fully adjustable fork with TiN surface treatment, for radial calipers
Front wheel travel 120 mm / 4.7 in
Front brake 2 x 320 mm semi-floating discs, 4-piston 4-pad calipers
Front wheel New Y-shaped 5 spoke design light alloy forged 3.50x17
Front tyre 120/70 ZR 17
Rear suspension Progressive linkage with fully adjustable Öhlins monoshock
Rear wheel travel 128 mm / 5 in
Rear brake 240 mm disc, 2-piston caliper
Rear wheel New Y-shaped 5 spoke design light alloy forged 5.50x17
Rear tyre 180/50 ZR 17
Fuel tank capacity 18,3 l / 4,8 US gal(including 3 l / 0,8 US gal reserve)
Weight * 192 kg / 439 lbs
Seat height 780 mm / 30,7 in
Instruments Speedometer, rev counter, high beam indicator, turn signals, oil pressure warning light, low fuel warning light, neutral light, water temperature. Immobilizer
Warranty 2 years unlimited mileage
Tank Colours Red
Frame and Wheel colours Red frame, black wheels
Engine
Type L twin cylinder, 4 valve per cylinder Desmodromic; liquid cooled
Displacement 749 cc
BorexStroke 94x54 mm
Compression Ratio 12,7:1
Power 86.5 kW - 118 HP @ 10250 rpm
Torque 81.5 Nm - 8,31 Kgm @ 8250 rpm
Fuel injection Marelli electronic fuel injection, 54 mm throttle body
Exhaust Single steel muffler with catalytic converter
Emissions Euro2
Transmission
Gearbox 6 speed
Ratios 1st 37/15, 2nd 30/17, 3th 28/20, 4th 26/22, 5th 24/23, 6th 23/24
Primary drive Straight cut gears; ratio 2,11
Final drive Chain; Front sprocket 15; Rear sprocket 35
Clutch Dry multiplate with hydraulic control slipper clutch
Rake 23.5°÷24.5°
Tank Colours Red
Engine
Displacement 749 cc
Emissions Euro2
Transmission
Gearbox 6 speed
