AEM's Dyno-Shaft Pro Series On-Vehicle Dynamometer
  • AEM's Dyno-Shaft Pro Series On-Vehicle Dynamometer
    Re: AEM's Dyno-Shaft Pro Series On-Vehicle Dynamometer
    http://www.aemelectronics.com/dyno-s...nv8hnekakogt50
    The Dyno-Shaft On-Vehicle Dynamometer Pro Series is a true on-vehicle dynamometer system that measures Torque and RPM while you drive to deliver Horsepower numbers in real time while you drive. It is a real dyno for your car that measures Horsepower, Torque and RPM as accurately as the most respected dynamometers, with the advantage of being able to gather this data in real-world conditions.
    Eliminate Guesswork - Know for sure if slower times are due to a loss of power, vehicle set up or driver error.
    Engine tuning - Stop trying to approximate real world test conditions and start testing in the real world! Finally you can test with actual intake air conditions, actual vehicle loading and the hundred other things that make a real vehicle behave very different than it does when on a dyno. In other words, it allows you to measure a vehicle’s power in real world conditions.
    Chassis Set Up - Know when the tires will break loose. Ideal for optimizing drag launches and determining the longitudinal forces your tires can handle in road racing.
    Torque Converter and Clutch development - Finally know what your Torque converter or clutch is doing while you are making a pass!
    Dyno It All - The Dyno-Shaft accurately reads in all conditions including steady state, uphill or downhill, even while coasting down! It can even measure the effectiveness of an Exhaust Brake on diesel applications.
    RECORDING, READING AND OUTPUTTING DYNO-SHAFT DATA
    At its core, the Dyno-Shaft Pro Series is a sensor that measures Torque and RPM and uses this data to output a vehicle’s Horsepower and Torque in real time. You will need a ‘host device’ to record, view and output data from the Dyno-Shaft. The following devices are capable of reading and logging data from the Dyno-Shaft via AEMnet:
    El fin de los bancos dinamometricos de rodillos de chiperos " mentirosos "....?
      que lindoo... lastima q nuncas a ser el fin jaja.. esta lindo el sistema, capaz q a un conocido le interese
          Mira que bueno, tiene unos strain gauges como los frenometros que usan en la vtv, ahora, para FWD no hay?
            Muy bueno che!!
              Excelente!
                Muy bueno! habia escuchado sobre algo parecido ya, pero poco y nada.
                En mi facultad lo estaban implementando en un laboratorio de electrica.
                  me fije en la pagina y hasta ahora, hay para el Yugo de la cruceta de un trasera, no ? en u delantera tendria que ir a una sola rueda o a las dos y mdir cada una de las ruedas y su variacion y aceleracion de giro
                  si se fijan es tambien de la forma que miden la potencia de un Top Fuel, con strain gauges en los palieres.........
                    Me hiciste acordar a esto:
                    Para aquellos que les interese saber que es un strain gauge:
                    http://es.wikipedia.org/wiki/Galga_extensiom%C3%A9trica
                    se usa para ensayos de materiales, traccion, flexion, torsion ,etc
                      No es nada nuevo esto, solo lo adaptaron a uso automotor. En la aeronautica se usa hace rato. Es muy confiable por lo que se y muy practico.
