Y de estos eh visto por aca
... pero no se si hay 2ptas
Calipers de NSX
Specs:
Engine
'99 B18C Integra Type R head and 1.8L block (both polished); JUN Auto Type 3 cams; TODA cam gears, valve springs, retainers and header; Civic Type R crank pulley; HASport motor mounts with U70A race bushings; HKS Super Mega Flow Reloaded intake; Spoon 70mm throttle-body, carbon Kevlar spark plug cover, radiator cap, radiator hoses and custom anodized oil cap; Mugen thermostat and thermo switch; Mugen oil pan with Spoon thermal barrier; HAMP oil filter; Fluidyne aluminum radiator; SPAL pusher fans; B&M Command Flow fuel pressure regulator; polished B16A2 fuel rail; NGK spark plug and wires; T1R catalytic converter; Vision exhaust hangers; RS*R exhaust; polished distributor; Odyssey PC680 battery; re-zinced engine hardware; berry pink powdercoated valve cover
Drivetrain
JDM YS1 transmission built by Jason Haradon; Wavetrac LSD; Exedy Stage 2 clutch and flywheel; ITR shift linkage; MFactory Pro 3.01 1st gear and 4.923 final gear; DC2 GSR 5th gear; polished transmission
Engine Management
Mugen N1 (EF9) ECU
Suspension & Chassis
Endless Zeal B6 coilovers (14K/10K springs); custom anodized and powdercoated Spoon front strut bar; ST front sway bar; ITR rear sway bar; Vision negative front a-arms; Next Miracle X-bar, c-pillar bar, and rear strut tower bar; Function 7 rear ITR style rear lower control arms with spherical bearings; MFactory rear camber kit and toe kit; Cusco front lower tie bar; Full Race front traction crossmember; purple anodized ASR rear subframe brace; EM Racing trunk brace
Brakes
Acura NSX front two piston calipers; Fast Brakes 11'' HD 2-piece front rotors; Power Slot rear rotors; Endless CCX brake pads; Earl's brake lines
Wheels & Tires
SSR EX-C Neo wheels 16x7.5'' +32, restored with chrome lips, machined faces and Jasper Green Metallic highlights; Project Kics Neo-Chro R26 lug nuts; old school Nitto NT 555R Drag front tires; AVS Intermediate rear tires
Exterior
Mostly original OEM Jasper Green Metallic paint; '92 spec front and rear bumpers with lightweight JDM support beams; JDM headlights and '92 taillights; JDP carbon-fiber front lip; custom modified brake duct front signals; JDM moldings; EC Works Type C side mirrors; FAL Flexite acrylic rear glass; JDM window visors; OEM rear sedan door handles; OEM antenna delete plug
Interior
ASM Recaro SPG in sparkle gold; Recaro side mount brackets; Bride seat rails; ITR yellow stitched shift boot; OEM rear speaker, A/C and side mirror delete panels
Calipers de NSX
Specs:
Engine
Drivetrain
Engine Management
Mugen N1 (EF9) ECU
Brakes
Wheels & Tires
Exterior
Interior
