Chevrolet corvette 06" blanco y violento!!
  • Chevrolet corvette 06" blanco y violento!!
    Block: LS2, 402 cid
    Compression ratio: 9.5:1
    Heads: L92, CNC-ported by Livernois Motorsports, 2.160 intake, 1.590 exhaust valves
    Cam: Livernois hydraulic roller, 0.599/0.610-inch lift, 236/246 duration at 0.050, 113 LSA
    Pushrods: Trend, hardened
    Rocker arms: Stock L92, 1.7 ratio
    Pistons: Livernois/Diamond, forged
    Rings: Diamond
    Crankshaft: Livernois/Callies, forged
    Rods: Livernois/Manley H-beam, forged
    Throttle body: Stock 90mm
    Fuel injectors: 65-lb/hr
    Fuel pump: Stock with Kenne Bell Boost-A-Pump
    Ignition: Stock coil-near-plug
    Engine management: Stock, tuned by Livernois/Dan Millen
    Power-adder: ProCharger D-1SC
    Boost: 13 psi
    Intercooler: ProCharger air-to-air
    Exhaust system: Kooks 1.75-inch long-tube headers, X-pipe with cats, Corsa catback
    Transmission: 6L80E, built by Rossler Transmissions
    Torque converter: Stock
    Driveshaft: Stock
    Front suspension: Stock control arms, Z06 sway bars, mono-leaf springs, shocks
    Rear suspension: Stock control arms, Z06 sway bars, mono-leaf springs, shocks
    Rearend: Stock IRS, 3.42 gear, axles, posi
    Brakes: Z06 14-inch, 6-piston front; Z06 13.4-inch, 4-piston rear
    Wheels: HRE 540R 19x10 front, 20x12.5 rear Front tires: Nitto Invo 285/30ZR19
    Rear tires: Nitto Invo 345/25ZR20
    Fuel octane: 93/110
    Current mileage: 25,000
    Miles driven weekly: 150
    About 800 rear-wheel horses, or roughly 1,000 horses at the flywheel
    Respuesta: Chevrolet corvette 06" blanco y violento!!
    q hermosura!! cuando lei q era blanco pense q no me iba a gustar!! jeje
      no sabia q venia blanco, queda hermoso!, y con ese caracolote mas todavia
        le doi..
          Una cosa de locos!!!!
            me encanto...esta perfecto...
