Engine: 2ltr block with 16v head,Custom nicasil sleeves, Custom billet cams, custom inconel and berilium valves,custom solid lifters, custom cam springs, titanium custom retainers, custom special material pistons, titanium custom pauter rods, ARP main stud kit,ARP head stud kit,custom main girdle, custom 4340 main bearings caps, custom 4340 billet crank. Custom dry sump system with pace parts.
Comp ratio: 11,2:1
Turbonetics turbo Y2k custom order Bbearing (120lbs~ 1200hp capable) , 8 x 850cc fuel injetors, custom intake, custom fuel rails, custom 4 to 1 exsaust steel manifold, turbonetics newgen wastgate,aeromotive 2 x fuel regulators, 3 x bosch fuel pumps, Haltech E11v2 engine managment, msd dis2 ignition, msd 4 x coils, custom 120mm steel exsaust pipe, turbonetics godzila bov, custom intercooler 82cm x 44cm x 8cm. Custom fuel cell.
Transmition: 4wd 6speed
Wheels: custom order 7 x 19'' work vsxx 5x100.
Tires: Pirreli pzero 215/35/19
Brakes: frond 405mm(16'') drilled custom discs with porsche gt3 leman 6piston calipers. Rear 355mm(14'') drilled discs with porsche 4pot calipers.
Suspension: Custom Made KW 3
Para más info lean este link
Unas pics de como era antes de todo esto:
Comp ratio: 11,2:1
