CHEVROLET CORVETTE Z06 06" ESE SI QUE QUERIA ACELERAR CON ALGO DE ESTILO!
  • CHEVROLET CORVETTE Z06 06" ESE SI QUE QUERIA ACELERAR CON ALGO DE ESTILO!
    Body
    Production C6 Corvette Z06
    Paint: OEM Machine Silver basecoat/clearcoat; Bodywork, paint preparation and applied by GM's Bowling Green Assembly Plant
    Chassis
    Frame: OEM C6 Corvette with hydroformed side rails
    Suspension: OEM C6 Corvette independent short/long arm with OEM front and rear composite leaf springs, Pfadt coilovers and QA1 anti-sway bars
    Steering: OEM C6 Corvette rack-and-pinion, power-assisted
    Brakes: OEM C6 Corvette 4-wheel disc brakes with ABS
    Wheels: (Street) CCW 505A, 18 x 9 1/2 inches in front, 19 x 12 inches in rear (Track) OEM C6 Corvette
    Tires: (Street) Michelin Pilot Sport, 275/35R18 in front, 345/35R19 in back (Track) Kumho V710, 295/35R18 in front, 335/35R19 in back
    Engine
    Modified GM Powertrain LS7 aluminum-block V8
    Built By: A&A Corvette, Oxnard, California
    Installed By: Late Model Racecraft, Houston, Texas
    Modifications: Block bored to 4.125 inches, Wiseco pistons, Callies 4.10-inch stroke crankshaft, Manley double valve springs
    Displacement: 438 cubic inches (7.19 liters)
    Compression Ratio: 12:01
    Cylinder Heads: OEM LS7 aluminum
    Ignition: OEM GM electronic coil-on-plug
    Induction: Hand-ported OEM LS7 intake equipped with LMR custom direct port nitrous oxide injection system and LMR custom stand-alone fuel system for the nitrous
    Camshaft: Hydraulic roller camshaft (.650-inch lift/244 degree duration)
    Exhaust: Kooks' 1 7/8-inch headers with 3-inch mid section, high-flow catalytic converters, OEM C6 Corvette cat-back exhaust with open/closed control switch
    Nitrous Oxide Induction System: One-off custom system by Late Model Racecraft with dual-bottle set-up, heaters, purge kit and stand-alone fuel system. Adjustable to 500 horsepower; set for 250 hp shot.
    Horsepower: Rear wheel (Without nitrous) 600 @ 6,800 rpm; Horsepower, Rear Wheel (With nitrous) 585 on 250 shot (Engine built for 400 shot, netting 1000 RWHP)
    Transmission
    Modified 6-speed manual transaxle with DTE Stage 5 Positraction differential
    Modifications: RPS carbon-on-carbon twin disc clutch
    Shifter: Callaway
    Final Drive Ratio: 3.73:1
    Interior
    Modified OEM C6 Corvette
    Modified By: Caravaggio
    Seats: OEM 2006 Corvette
    Carpets: OEM 2006 Corvette
    Instrumentation: OEM C6 Corvette (0-200 mph speedometer, 0-8,000 rpm tach with 6,300 rpm redline, plus ammeter, oil pressure, oil temperature, coolant temperature and fuel level gauges), in dash, plus auxilary AutoMeter pressure gauges (for fuel and nitrous oxide) in console next to shifter
    Sound System: OEM C6 Corvette
    HVAC: OEM C6 Corvette
    Respuesta: CHEVROLET CORVETTE Z06 06" ESE SI QUE QUERIA ACELERAR CON ALGO DE ESTILO!
    Veniamos bien hasta que puso una aguila en el capot jejeje muy lindo toda la furia un vette con gas..
      no comparto el diseño de las lñantas, creo que las originales le quedan mucho mejor. El resto un misil!!!
        muy lindo!! pero con lo q anda de fabrica ni le hubiese puesto gas jeje
          trrible...que bestia...
            Esto es facil vos tenes el mejor vette y viene otro con uno igual con gas y te gana tenes 2 opciones o le pones una mechota y lo vas a buscar o sos mediocre y lo dejas std y quedas de hijo de por vida jejejeje
              me parece a mi o eso es una historia real lo qe tas contando sonto xenonizado ? jajaja
