PLYMOUTH BARRACUDA 70" LOS CHICOS Y LAS CHICAS QUIERE ROCK!
  • PLYMOUTH BARRACUDA 70" LOS CHICOS Y LAS CHICAS QUIERE ROCK!
    Engine: As if 440 ci weren't enough, Jody ponied up for a stroker package from 440source.com. It consists of a forged 4.15-inch crank, forged rods, and Ross flat-top pistons. At zero deck height, these pistons yield a tight 12.5:1 compression ratio. We're guessing Jody has to add a splash or two of race gas at each fill-up. The block itself has a 1972 date code and was machined and clearanced for the stroker crank by Mike Landy. Moving up the block, you'll find a pair of Edelbrock Victor cylinder heads that were custom-ported by Porter Racing Heads in South Burlington, Vermont. The company also opened up the intake ports to Max Wedge dimensions. Owner Dwayne Porter matched a custom-ground Comp cam to Jody's combination. It's a single-pattern solid-roller type that measures 276 degrees at 0.050 and 0.680-inch lift. Smith Bros. pushrods lean on a set of T&D 1.5:1 shaft mount rocker arms that open up 2.20/1.810 valves. The springs are also from Comp, while the fasteners are from ARP and the gasket kit is from Cometic.
    Induction: That's an Edelbrock Super Victor Max Wedge intake manifold that draws air in through a 1,050-cfm Carb Shop-prepped Dominator.
    Power: Jody listed his power figures as 720 hp at 6,300 and 656 lb-ft at 5,500. Based on his 10.41-at-131-mph dragstrip pass, we have no reason to doubt him.
    Exhaust: Two-inch TTI headers route the exhaust into a 3 1/2-inch exhaust system bent up by Morse Muffler in Burbank, California.
    Transmission: There's a beefed-up 727 TorqueFlite behind Jody's oversized RB. It's been built with a billet front drum and an A&A reverse-manual valvebody. He ratchets through the gears with a B&M Pro Stick shifter.
    Rearend: That's a Dana 60 in back, but it's actually out of a '68 Chevrolet 3/4-ton pickup and had to be narrowed to fit the car. It houses Richmond 4.56:1 gears on a Power Lock differential and 35-spline Moser axles.
    Suspension: The front suspension is stock and still has the car's original 318-spec torsion bars. Lakewood drag shocks allow the front to rise on hard launches, and a 20:1 Mopar steering box allows Jody some looseness at the steering wheel so he doesn't actually send the car into the wall if he hiccups while making a pass. The rear suspension is basically stock. Jody widened the rear wheeltubs to fit bigger tires, added a set of CalTracs bars, and uses Rancho five-way adjustable shocks.
    Body: The Barracuda's chassis is mostly stock. Jody added homemade subframe connectors and welded in a Chris Alston eight-point rollbar to increase rigidity and up the safety factor, too. The body is all steel with the exception of the fiberglass hood, fenders, and front valance. It tips the scales at about 3,400 pounds.
    Brakes: Aerospace Components drag race brake kits are mounted front and rear. The front rotors measure 11 3/4 inches and the rears measure 11 3/8.
    Wheels/Tires: Simple but effective, Jody's car rolls on Weld Draglite wheels. Up front, BFGoodrich 225/70R15 tires are mounted on 15x5 wheels, and out back, 31x16.5-15 Mickey Thompson ET Street tires are mounted on 15x12 wheels.
    Paint/Body: Jody did a lot of the bodywork himself, replacing the clapped-out quarter-panels a few years ago. He recently had the car painted at Dura Glow in Van Nuys, California, for the paltry sum of $1,200. He squeaked by with this deal of the century by doing most of the prep work himself. He even provided the shop with a gallon of primer.
    Interior: Aside from the rollbar, the interior is mostly stock with a smattering of Auto Meter gauges and RCI five-point harnesses. The front seats were from a Mazda RX-7 Jody's company provided for a movie.
    Y DESPUES HABLAN DE MICHIS FOOSE!!
    Respuesta: PLYMOUTH BARRACUDA 70" LOS CHICOS Y LAS CHICAS QUIERE ROCK!
    Muy bueno!!! Pero por favor, sin vidrios pola y con el tapizado de la butaca arreglado y limpio... jajaja ;)
      seeeee
      eso es lo que vaaaaaaaa.
      que bueno que está....
        Un emblema dentro de los muscle cars, Una bellesa. Ahora si tuvieran la posibilidad de tener uno, lo modifican o lo dejan como vino de fabrica?? ( + unas buenas patas..obvio)
        Pregunta de ignorante, cual es la diferencia entre el hemi cuda y este?? el motor hemi?? o hay algo mas?
          que belleza es el auto de blade jajaj
            es un amor!!! que linda está... asi en negra es muuuy violenta!
              toda la violencia, que lindo pegar una vueltita en eso, que el dueño te diga toma ponela toda ajaajja, no paro de mirar las fotos!
                Bastante roñoso el dueño compro las butacas en warnes jejejej..
                Muy lindo fierro lo que deben sonar esos escapes terribles...
                  Miralo al cuda con bum bum, jajaja. Orgasmico. Es el muscle que mas me gusta!!!
                    jajaaaa seeee!! y doble bumbum eh!! lo ve Pulgo y se vuelve loco
                      perfecto...
                        que fierro!!!!!!!!!
                        hacia bastante que venis posteando modernizados,por fin lo qu eva!!
                          Y ni hablar del qluilombo de cables que tiene adentro .
                            jojoojoo
                            aguante el bum bum!!!!!!!!!!!!!!
                              que espectaculo que lindo auto
