DODGE CHALLENGER 70" LA BALLENA AZUL ATACA!
  • DODGE CHALLENGER 70" LA BALLENA AZUL ATACA!
    ENGINE
    Type: Chrysler 416ci small-block
    Block: Chrysler block, bored to 4.080 inches
    Oiling: Melling high-volume oil pump, Milodon pan
    Rotating assembly: Mopar Performance 4.000-inch steel crank, Scat H-beam rods, Keith Black 9.3:1 forged pistons
    Cylinder heads: ported Edelbrock Performer RPM aluminum castings with 2.08/1.60-inch valves; Hughes springs and retainers
    Camshaft: Hughes 242/246-at-.050 hydraulic flat-tappet cam, .592/.606-inch lift, 110-degree LSA
    Valvetrain: Hughes lifters, 1.6:1 rockers, and timing set
    Induction: ported Edelbrock Victor intake manifold, Sean Murphy 830-cfm carburetor
    Ignition: MSD billet distributor, 6AL ignition box, coil, and plug wires
    Fuel system: Rick's Hot Rod Shop tank; Aeromotive in-tank pump and regulator
    Exhaust: TTI Performance 1¾-inch long-tube headers and X-pipe, dual 2.5-inch DynoMax mufflers
    Cooling: Mopar Performance pump; Be Cool radiator and dual electric fans
    Output: 555 hp at 6,100 rpm and 552 lb-ft at 4,600 rpm
    Built by: Hughes Engines (Washington, IL)
    DRIVETRAIN
    Transmission: Phoenix 4L60E overdrive, adapter plate, custom flexplate, and 3,000-stall coverter; Compushift computer, Lokar shifter
    Rear axle: Chrysler 8 3/4-inch rearend, Auburn limited-slip differential; Moser 30-spline axles and 3.70:1 gears
    CHASSIS
    Front suspension: Ridetech tubular control arms, air springs, and shocks; stock sway bar
    Rear Suspension: Ridetech four-link, air springs, shocks, and subframe connectors
    Brakes: Baer 13-inch discs with two-piston calipers, front and rear
    WHEELS & TIRES
    Wheels: Boze Pro Touring 18x8 (4.5-inch backspace), front; 18x10 (5.75-inch backspace), rear
    Tires: Goodyear Eagle F1 225/45R18, front; 295/45R18, rear
    Respuesta: DODGE CHALLENGER 70" LA BALLENA AZUL ATACA!
    el yanki ke mas me gusta
      Una locura!!!
        buenissimo yo le pongo un 12 pts.
          Es un polvo rodanteee
            que hermosa... 555hps para pasear de vez en cuando, porque no creo que pasearia si la tubiera
              hermosura total...
                es hermosisimo.
                es un 9.5,le falta la manual ajjaja
                una duda boluda.....
                ¿donde esta el cuentavueltas?
                no lo veo
                  Originally posted by DODGE N´ROSES View Post
                  es hermosisimo.
                  no lo veo
                  No te quiero mentir pero creo que es el ultimo reloj de la derecha si no me equivoco!
                  ENCIMA TIENE AIRE! GROSOOO UNA BELLEZA
                    Naaa se va al re carajo eso...
                      Cuando no le este sacando la mierda lo tendria en una habitacion de vidrio hermeticamente cerrada.
                        no hay con que darle ....como me gustan los muscle
                          Pero que palangana mas hermosa lpm, jaja. Un polvo con todas las letrasssss.
                            Para mi Habria que bannear de por vida a los user q hacen este tipo de post
                            Estan jugando con la salud de los integrantes dle foro jajajaja
                            IMPECABLEEEEE Y DIVINO
                              Precioso el Challenger, no comparto las llantulis, el resto está bárbaro
