Engine 3.0L 2JZ-GTE; HKS 280 degree cams, cam gears, and DLI; fully-ported head; Supertech valves; Ferrea valve springs and retainers; customized GReddy intake manifold and turbo manifold; 80mm custom built Turbonetics/Garrett hybrid turbo; Precision turbo blanket; TiAL blow-off valve and wastegate; Denso 850cc injectors and twin fuel pumps; Aeromotive fuel regulator; Titan twin feed fuel rail; NGK spark plugs; custom intercooler and piping; AEM boost controller; custom 90mm throttle-body; Eagle H-Beam connecting rods; ARP head and rod bolts; CP forged pistons; OEM knife-edged crankshaft; bowtailed mains; Fluidampr pulley; custom baffled oil pan scrapper, oil cap and catch can; Koyo aluminum radiator; Flex-A-Lite electric fans; Samco hoses; Illtech 4'' intake and downpipe; Boost Logic 4''exhaustDriveline OEM 6-speed Getrag transmission; TRD limited slip differential; B&M short shifter; RPS Stage 3 clutch; billet transmission and differential mounts; Fidanza flywheel
Engine Management AEM EMS
Footwork & Chassis TEIN RA coilovers; Titan front and rear sway bars; RZ Racing bushings and camber kits
Brakes K Sport 8-piston front calipers with 2-piece 14" rotors; stainless steel brake lines; AP Racing front pads; Hawk Performance rear pads
Wheels & Tires Volk Racing CE28N 19x9.5 (front) and 19x10.5 (rear); BF Goodrich g-Force T/A KDW 2 tires 275/35ZR19 (front) and 295/35ZR19 (rear)
Exterior modified aftermarket front lip; '98 OEM headlights; 8,000K HID kit; LED coverted lights; pulled and stretched fenders and quarter panels; flush mounted LED third brake lights; shaved spoiler, side markers, rear wiper, and antenna; custom bronze pearl metallic
Interior Recaro seats; custom gauge panel; AEM gauges; Personal steering wheel; NRG quick-release; custom push button ignition
