QUE LOS HERMANOS SEAN UNIDOS ESA ES LA LEY PRIMERA!
  • QUE LOS HERMANOS SEAN UNIDOS ESA ES LA LEY PRIMERA!
    SON HERMANOS PERO COMPETENCIA EN FAMILIA NO HACE NADA MAL EH
    AZUL
    Engine
    427 center oiler block, 0.030-inch over
    4.260-inch bore
    Scat 4.25-inch stroker crank
    485 cubic inches
    Ported Edelbrock aluminum heads, 2.19/1.73 valves
    Jesel shaft roller rockers
    Holley 950 cfm carb
    Blue Thunder dual plane intake
    Custom Reed solid roller camshaft
    Transmission
    Tremec TKO five-speed
    Hurst shifter
    Rearend
    9-inch axle
    3.91 gears
    Traction-Lok differential
    31-spline axles
    Exhaust
    FPA Tri-Y headers
    2 1/2-inch pipes
    Flowmaster three-chamber mufflers
    Suspension
    Front: Grab-A-Trak 1 1/8-inch swaybar, 620 springs, poly bushings, KYB shocks
    Rear: Grab-A-Trak 4 1/2 leaf mid-eye springs, heavy-duty shackles, staggered KYB shocks
    Brakes
    Front: Baer "Track" kit 13-inch slotted/drilled/zinc-washed rotors, two-piston PBR aluminum calipers
    Rear: Baer "Track" kit 13-inch slotted/drilled/zinc-washed rotors, single-piston PBR aluminum calipers
    Wheels
    Front: Vintage Wheel Works V45, 17x8, 4.5-inch backspacing
    Rear: Vintage Wheel Works V45, 17x9.5, 6.25-inch backspacing
    Tires
    Front: BF Goodrich g-Force T/A, P245/45R17
    Rear: BF Goodrich g-Force T/A, P255/50R17
    BLANQUITO
    Engine
    433 cubic inches
    Stock block, 0.030-inch overbore
    4.160-inch bore
    3.980-inch stroke
    Stock head castings, prepped by Paul's Automotive Engineering
    Stock Holley 735cfm carb
    Stock cast iron intake
    Comp Cams hydraulic cam
    Comp Cams roller rockers
    Transmission
    Lakewood bellhousing
    McLeod clutch and billet flywheel
    Rearend
    9-inch axle
    4.30 gears
    31-spline axles
    Exhaust
    Stock CJ exhaust manifolds
    MagnaFlow stainless dual exhaust
    Suspension
    Front: Global West upper/lower control arms, strut rods, and springs; Koni shocks; Grab-A-Trak 1 1/8-inch swaybar
    Rear: stock w/Koni staggered shocks
    Brakes
    Rear: Baer "Sport" kit 12-inch slotted/drilled/zinc-washed rotors, single-piston PBR aluminum calipers
    Wheels
    Front: Wheel Vintiques billet Magnum 500s, 17x8, 4.5-inch backspacing
    Rear: Wheel Vintiques billet Magnum 500s, 17x9.5, 6.25-inch backspacing
    Tires
    Respuesta: QUE LOS HERMANOS SEAN UNIDOS ESA ES LA LEY PRIMERA!
    NO NO Y NOOOOOOOOOOO!!!!!!!! POR DIOS QUE BELLEZASSS!!!!
      perfectos!!!!!!!!!
        el blanco... es uno de los 70 modificado?... por que el interior en especial el volante es de los 70
        impacable la calidad de estos post ;)
          ESO es un mustang como la gente...no el 67 chuneado que posteaste el otro dia.
            Estoy de acuerdo con vos pero el otro lo que menos me importa el aspecto que tiene lo que va es la planta impulsora.
            Igual el fastback no es mi prefierido prefiero mil veces el coupe
              el celestito, lpm...y nacio de la falketaaa ehh!!!
                con ese criterio hay cada cosa horrenda con tremendos ponys adentro....
                mantengamos la calidad que venis trayendo chris...
                y lo que dice ansel es cierto, la carroceria del mustang nacio de la "estructura" del falcon...por eso cualquier parte de tren delantero que venga de mustang se puede meter en el falcon....quien lo diria no?
                  Claro entonces tranquilamente a un falcon de aca le podes meter una suspencion Global West de mustang fase uno???
                    sep...asi como le podes poner la reforma para tren delantero de taunus(o mustang 2...siguen los parentescos viste jajaja) y le metes un big block...la unica diferencia que es la mayor cagada del falcon es que los tirantes superiores(las 2 chapas que cruzan en el vano arriba) en nuestro falkito llevan los numeros de chasis asi que BB es medio dificil sin sacarlas...y ahi cagas todo.
                      Unos buenos ford clasicos, como a mi me gusta
                        que navessssss!!!!!!!!!!!!!!!!!!por favor!!!
                          la puta maadre! Estos si son Mustang´s!!!
                          Los interiores increíbles! Y las llantas del blanco la rompen!
                            Quee naveeeeees !
                              increible que esten tan perfectos los 2...
