RAMBLER AMERICAN 330 64" ALGO TRANQUI PARA HOY!
  • RAMBLER AMERICAN 330 64" ALGO TRANQUI PARA HOY!
    Chassis
    Unusual for an R&C feature car, the American is a uni-body, and is pretty much stock, though Keith did notch the front of the frame to clear the lower A-arms. The rear parallel leaf suspension was retained, while bolt on airbag brackets were fabricated and installed at each corner, along with Monroe shocks. Keith's buddies at Stoked Out Specialties helped with the three-month "build".
    Drivetrain
    Backed by the stock, yet superbly named, Flash-O-Matic auto trans, the original 196ci flathead six-cylinder still purrs under the hood, with less than 50,000 original miles on it in 45 years! Keith painted the motor Olds Gold, dressed it with a Harley air cleaner, chrome head studs, and Honda CB350 finned ignition cover hiding the heater valve and a chrome oil filter and pulleys.
    Body & Paint
    Re-chromed bumpers and emblems removed from the hood are about the extent of the body mods, though it had received fresh Bengal Ivory paint when Keith took ownership.
    Wheels & Tires
    Here's one of the few deviations from stock, and the reason (apart from the lowering) why the car looks so good. Billet Specialties' Vintec 7x18s and 8x18s replace the stamped steel stockers, wrapped in 215 and 225 40ZR18 Yokohama Parada rubber.
    Interior
    Totally stock, but very cool in Emperor Gold, the American's interior features reclining split backs on the front bench seat, and even the original radio in the center of the dash. A discrete gauge under the left side of the dash monitors the airbags.
    Respuesta: RAMBLER AMERICAN 330 64" ALGO TRANQUI PARA HOY!
    mooooooooy lindo bicho
    OFF: y despues dicen que el torino es netamente argento.sisi tanto como el falcon
      hermoso!!!,lastima el flat,yo le meteria un torino 7,jajaja(para los que dicen que es igual al torino).putos
      ---------- Post added at 11:54 ---------- Previous post was at 11:53 ----------
      vess,estoy escribiendo y ya salto el primer gil,hincha de ford tenia que ser!!!!
      ---------- Post added at 11:56 ---------- Previous post was at 11:54 ----------
      que le ves de parecido al torino,el motor(no),el interior(Menos) ,el falcon vino de alla tal como era,no empecemos con esta discusion pelotuda una vez mas
        eeeee por que lo de gil....que necesidad habia...
        el diseño de carroceria es muy similar o me vas a decir que no,si molesta lo que dije decime y lo borro no soy de confontar y menos en boludeces
          va con onda rama,no te chives!!!,jaajajajaja,justo a uno de ford le digo no te "chives" juju!!
            feliz año
              Originally posted by ramasprint80 View Post
              feliz año
              feliz año rama!!!!,un abrazo
                Ahh, bueh! son todos choborras aca.... asi que me uno a la banda....
                Y yo tambien le veo un aire al Torino...
                Es una preciosura ese Rambler. No hay nada que me disguste, es perfecto!!!
                  salud!!!
                    ohhhhhhh el toriiiino, el auto 100% argentino!!!! jaaaaaaaaa, el unico auto argentino lamentablemente es el justicialista...
                      Hay que hacer justicia por el justicialista
                        nooo,ika era una empresa yugoeslava el r 12 lo fabrico gmc en estados unidos y al rambler lo fabrico gmc, en españa,andaaaa,tomatelas !!!!
                        ---------- Post added at 12:49 ---------- Previous post was at 12:47 ----------
                        te lo voy a poner de esta manera:el torino se fabrico en alguna otra parte del mundo,tal como es aca en argentina?,pensalo
                          lindo el torino ehh
                            Digamos que todos los paises tuvieron una partuza y se creo el torino
                            ITALIA DIO EL DISEÑO
                            EE UU DIO LA BASE Y MOTOR O LA BASE DEL MOTOR
                            ALEMANIA DIO LA CAJA
                            ECT ECT ECT
                              Muy prolijo, me encanto!
