Chevrolet laguna s3 76" despues de tanto ovalado uno bien cuadrado!
  • Chevrolet laguna s3 76" despues de tanto ovalado uno bien cuadrado!
    ENGINE
    Type: Chevy 460 big-block
    Block: factory Chevy bored to 4.280 inches
    Oiling: stock replacement oil pump, Moroso pan
    Rotating assembly: GM 4.000-inch forged crank, steel rods, forged 13.0:1 SRP pistons
    Cylinder heads: ported GM rectangle-port iron castings with 2.25/1.88-inch Manley valves
    Camshaft: COMP Cams 260/266-at-.050 solid roller, .685-inch lift, 112-degree LSA
    Valvetrain: Crane lifters, 1.7:1 rockers, and double-roller timing set
    Induction: Edelbrock Victor intake manifold, Holley 1,050-cfm Dominator carb
    Ignition: MSD 6AL box, distributor, coil, and plug wires
    Fuel system: MagnaFuel pump, Holley regulator
    Exhaust: Hooker 2 1/8-inch long-tube headers, dual 3.5-inch Borla XR1 mufflers
    Cooling: Ron Davis radiator, Weiand water pump, Flex-a-lite electric fan
    Built by: Beech Motors (Johnstown, OH)
    DRIVETRAIN
    Transmission: Coan TH400 auto and 4,500-stall converter; Hurst shifter
    Rear axle: GM 12-bolt rearend, 4.10:1 gears, limited-slip differential
    CHASSIS
    Front suspension: rebuilt stock with Competition Engineering adjustable shocks
    Rear suspension: rebuilt stock with Competition Engineering springs
    Brakes: stock discs, front; stock drums, rear
    WHEELS & TIRES
    Wheels: Centerline Convo Pro 15x4, front; 15x10, rear
    Tires: Goodyear 205/75R15, front; Hoosier 28x13.5x15 Quick Time Pro, rear
    Respuesta: Chevrolet laguna s3 76" despues de tanto ovalado uno bien cuadrado!
    Que lindo que esta. parece esos que corrian en la NASCAR si no me equivoco.
    Ladys and Gentleman..... start your engines......
      Lindo, pero igual sigue siendo un auto dificil de digerir jaja...
        bien loco,por fin termino la semana d ford y volviste a los buenos autos jaja...no s lo tomen a mal...
        hermoso auto,m encanta la linea rara q tiene...
          uhhhhhh q recuerdos x dios!!!!:..
          mi abuelo tenia uno de estos.... del mismo color... lamentablemente lo dio vuelta en un viaje a la costa...
          si encuentro alguna q otra foto despues la escaneo y la subo...
          hermoso la verdad!
            JOJOJO, TERRIBLE!!
            Ahora que desquiciado, toda la ferreteria encima y frenos traseros a tambor, bien yankee eso!!
            PD: Como me excitan esas llantas, el dia que pueda se las clavo a la dodge!!
              Que mierda es lo rojo que esta adentro del espiral?
