Semana moparera!! Dia 4 plymouth road runner 70" dedicado a nikos_nos!
  • Semana moparera!! Dia 4 plymouth road runner 70" dedicado a nikos_nos!
    Engine: The mill was built by Hensley Racing in Knoxville, Tennessee. Starting with a 4.500-bore Mopar Performance Hemi block, Hensley added a 4.250-stroke Callies crank for 540 inches. The rotator also has Manley rods, and custom Ross pistons that deliver an 8.5:1 compression ratio. Why so low? It's got a manifold full of BDS 8-71 with twin 850-cfm Mighty Demons. The heads are from Mopar Performance and feed into Hooker Super Comp headers and a set of 3-inch Flowmasters. "We had removed the K-frame, so there were no conventional motor mount locations, and we had changed the configuration of the transmission with the Gear Vendors unit. That means you just have to move everything a little bit this way and a little bit that way before it is right," says Troy.
    Transmission: Local transmission specialist James Kitchens rebuilt the 727 TorqueFlite and added a Cheetah reverse-manual valvebody and a Gear Vendors overdrive unit. "That is supposed to be a bolt-on type of part, but we still had to hammer on the trans tunnel a bit to get it in there. It gives the car a six-speed ratio ranging from the stock 10.0:1 or so in First with the 4.10:1 rear to an overdrive of about 3.20:1 in Third," says Troy. "It was a job just getting everything to fit; there are no quick answers when you are customizing a car this way."
    Paint/Body: Of course, there was a question of color. The hue selected was PPG FY1, a blazing yellow that was applied to the cleaned-up metal by Martin Worth of Auto Refinishers in Newnan, Georgia. This one is not going to sneak up on anybody. A fiberglass hood was purchased and cut for the blower.
    Suspension: In the rear, a set of Competition Engineering Slide-A-Link bars and drag shocks were added for a bit of traction. In front, the B-Body has a Magnum Force tubular K-frame with coilovers and a power rack-and-pinion steering setup.
    Wheels/Tires: A big car looks cool with big wheels and tires-unless they are too big. The front tires are Billet Specialties 17x8s with 245/45R17 Nitto tires. For traction, the Road Runner uses 18x9.5 rears with 305/35R18 Nitto rubber.
    Differential: The power is mostly put to the ground using a Dana 60 with 4.10:1 gears and a set of Moser axles.
    Interior: The stainless dash, with Auto Meter gauges and a DVD player, was built by Eric Kimbrel. The upholstery is stock.
    BEP BEP
    Respuesta: Semana moparera!! Dia 4 plymouth road runner 70" dedicado a nikos_nos!
    este era el modelo con "huecos" en el chasis???
    NO SE CUAL poner de fondo de pantalla... me encantoo!
      Me mato la botellita de nitro marca ACME.
      Yo le cambiaria las llantas solamente.
      Un cañon
        me hice caca encima
        hermoso
          la garrafa fue lo mejor ^^
            Originally posted by skelo View Post
            me hice caca encima
            hermoso
            Somos dos! y justamente de la misma manera que en Brasil!
            FROM HELL!, que belleza de bicho.
            Aprovecho este medio para pedir informacion sobre Nikos, no contesta llamadas, ni msjs...
              Seeeeeeeeeeeeeeeee que preciosuraa!!
              Por algo amooo los moparrs!! Jaa son preciosos y tiene muucho poweerr
                Me hice pis encima.
                  Excelente!
                  La puta madre loco!! Bastaa!!!
                    perfectoo!!
                    8.8 litros,jaja cada cil es un 128!!
