FORD MUSTANG 68" NACIDO PARA LA PISTA!
  • FORD MUSTANG 68" NACIDO PARA LA PISTA!
    ENGINE
    Type: Ford Motorsports 302-crate engine
    Bore: 4.000-inch
    Stroke: 3.000-inch
    Displacement: 302 ci
    Compression ratio: 9.0:1
    Camshaft: X303 hydraulic roller
    Block: Fomoco
    Crankshaft: forged
    Cylinder head: Ford GT40X aluminum
    Carburetor: Holley 600cfm double-pumper
    Header: Hooker COMP 1 5/8-inch
    Mufflers: Spintech
    Ignition: MSD 6AL
    Output: 360 hp @ 6,000 rpm
    340 lb-ft @ 5,000 rpm
    DRIVETRAIN
    Transmission: Super Duty T5 World Class five-speed
    Rear axle: Ford 9-inch, 3.890:1 gear ratio, Detroit Locker
    CHASSIS
    Front suspension: Open Tracker Products full roller upper and lower control arms, Spax adjustable shocks, Total Control tie-rod adjuster sleeves, eccentric eliminators and coil springs
    Rear suspension: Precision Machines five-leaf spring, Total Control torque arm
    WHEELS AND TIRES
    Wheels: Vintage Wheel Works V45, 16x8 front and rear
    Tires: BFGoodrich g-Force R1 245/45ZR16 front and rear
    Respuesta: FORD MUSTANG 68" NACIDO PARA LA PISTA!
    ARMOSOOOOOOOOOOOO
      Haaaaaaaaaaaaaaa COMO ME GUSTAA!
        muy bonito, es el modelo de mustang ke me gusta con cola, los fastback los veo parecidos a la taunus y me dejan de gustar.
          que lindo que esta, cerca de casa cuando era chico habia una de esa linea.. blanca.. pero oxidada... toda para restaurar
            viiooooooooooollllentoo....
              FORD (L)
