Sobretodo en el centro.
***OUTLAW WAGON***
For auction is a 1975 Buick Estate Wagon. No motor or Transmission. It started with a local derby with limited weld rules. The car did not pass inspection. Took it home and started to weld. Decided to go OUTLAW with it. I have too many projects going on to complete this car. The car was ran once without the plate steel. The only damage was to the rear passenger door. Door can be easily patched. The frame is perfectly straight. All body mounts have been taken out. Frame has not been plated, but the humps are fixed. The front frame rails are pinned. Rear axle is a 3/4 ton full floater - 8 lug. I have a set of 5.29 ratio gears for it that I will add to the auction. There are 13 leaf springs on each side with 2 of the 13 over 1/2" thick. One above and one below the main leaf. Rust isn't bad for an Illinois car. Mainly were you place your feet. Front floors have been patched. Tailgate is halfway down and full of concrete. Still a VERY solid car. You can go 2 routes with this car. Complete it and run full outlaw or strip the plating and run pro modified. The tranny shifter stays with the car but the fuel tank will be removed. I will have the right rear tire fixed before the winning bidder picks it up. I should have all the remaining diamond plate and grader blade steel needed to complete the other side, but it is not included in this auction. Purchase of this steel can be discussed with the winning bidder. I will assist you in loading the car or delivery to bordering states is available for a fee. The car is located in Lewistown, Illinois. Please emial me with question or for more pics. Car is for sale locally and I reserve the right to end this auction early.
a tan solo : US $1,025.00 ! una ganga!
***OUTLAW WAGON***
