CHEVROLET BEL AIR 55" MUY MUY MUY VIOLENTO!
  • CHEVROLET BEL AIR 55" MUY MUY MUY VIOLENTO!
    Engine: 526ci (8620cc) Hemi, TFX billet fuel block, Brooks B2 rods, Bryant crank, JE pistons, 11.3:1 compression ratio, Stage 5 fuel heads, titanium valves, Manley springs, Crane Cam, one-inch lifters, Littlefield 16-71 Supercharger, Quadstar injector, Waterman fuel pump, MSD Mag 44 magneto, Future Performance stainless zoomies
    Driveline: Crower triple-plate 10-inch clutch, Trick titanium bellhousing, Lenco CS1 four-speed transmission, manual shifted, chromoly drive shaft, Strange Ultracase 9.5-inch diff head, 40-spline Strange axles, Future Performance sheet metal housing.
    Suspension: Strange heavy-duty adjustable front struts, QA1 double adjustable rear coil-over shocks, Future Performance four-link
    Brakes: Strange four-pot callipers, 280mm front discs, Wilwood four-pot 280mm disc rear, Strange master cylinder
    Wheels: 15x4.5 and 16x16-inch Weld Alumastar rims, Hoosier front runner tyres and 34.5x17 Hoosier slicks
    Exterior: Full fibreglass body, moulds made by Future Performance and copies made by Mike Shaw Fibreglass. Paint by Bretto — Future Performance. Airbrush work by Warren Houston — Custom Dept. Sign writing by Mahana Graphics/Hippie
    Chassis: Tynan design, built completely by Robert Tynan — Future Performance — as are the wheelie bars, fuel and oil tanks
    Interior: Not much! One race seat, RJS harness, Jegs switch panel, Auto Meter tacho, oil and boost gauges, 20lb DJ fire system, aluminium panels and steel floor by Chris and Bob
    Performance: 6.45 @ 213mph
    Respuesta: CHEVROLET BEL AIR 55" MUY MUY MUY VIOLENTO!
    excelente!!!!!!!!!!!y con la data
      Ajjjjjj como le gusta la nafta a ese motorcito, eso si es power. ford chupala, si no te moris intoxicado del la de nafta quemada que vas a chupar
        UFFF chiquito el supercharger q tiene eh!... q locura...
        pregunta: siempre me pregunte q son esas correas q pasan x el motor... desde el super charger hasta abajo... me refiero a las q son color aluminio (q tienen una etiqueta q dice DJ safety o algo asi) alguno sabe?...
          tremendo...ES CHEVROLET...
            pregunta algo tonta a lo mejor, pero que funcion tiene la emboltura de la caja y de que material sera
