Lingenfelter 427 Corvette Twin-Turbo
  • Lingenfelter 427 Corvette Twin-Turbo
    General Information
    Price: $165,000
    Miles Per Gallon: 15/24 mpg
    Curb Weight: 3340 lbs
    Layout: Front-Engine/RWD
    Transmission: 6-Speed Manual/5-Speed Automatic
    Engine
    Type: Twin-Turbo V8
    Displacement: 7007 cc
    Horsepower: 802 bhp @ 4600 rpm
    Torque: 866 lb-ft @ 3600 rpm
    Redline: 6500 rpm
    Performance
    0-60 mph: 1.97 sec
    0-100 mph: 4.33 sec
    Quarter Mile: 8.95 sec @ 153 mph
    Skidpad: 1.01g
    Top Speed: est 240 mph
    Braking, 60-0 mph: --- ft
    Slalom Speed: --.- mph
    Lingenfelter 427TT package includes:
    Two true ball bearing turbochargers
    Two high efficiency air to air chargecoolers
    Custom molded Samco silicone air ducts
    4 into 1 custom cast exhaust manifolds
    Two cast turbo outlet adapters
    Turbocharger scavenge pump
    Turbo oil drain reservoir
    Two K&N 360 degree conical air filters
    Heat shields and stainless clamps
    Professional installation, testing and tuning
    Corsa stainless steel exhaust system
    Turbocharger water feed and return hoses
    Turbocharger oil feed and return hoses
    Gaskets, spark plugs and fluids
    Custom 7.0 L aluminum
    CNC Porting and polishing of LS6 cylinder heads
    Port matched LS6 intake manifold
    Billet steel connecting rods
    Forged 4340 crankshaft
    Forged aluminum pistons
    Custom hydraulic roller camshaft
    High performance valve springs & lightweight retainers
    Stainless steel one piece heavy duty intake valves
    Inconel one piece heavy duty exhaust valves
    Three angle valve job, checking of spring tensions & heights
    Computer balanced rotating assembly
    Reassembly and blueprinting of engine
    Properly sized fuel injectors and high capacity fuel system
    Corsa Performance stainless steel exhaust system
    Professional installation, testing and PCM recalibration
    LPE's 2 year / 24,000 mile warranty
    mamadera...!! esta que explota... vi acelerar un corvette de los nuevos en una cuadra y parecia que se iba a subir a la vereda.. esto directamente debe ser imprecionante.....!!! :twisted:
      Jojo, terrible, encima te dan garantia del laburo x tanto tiempo!
        Que fierro por Dios!
          increible misil
            Aca les dejo un video de lo que puede hacer este auto.....
            Lingenfelter Power
            PD: El otro auto hace 13 y monedas en el 1/4
              [sorpresa] [sorpresa] [sorpresa] [sorpresa] [sorpresa] [sorpresa]
              Sin palabras........ hermoso... [sorpresa] [sorpresa] [sorpresa]
                que bueno esta me encanta
                  nah.... que pedazo de fierro... no puede acelerar de 0 a 60mhp en 1.92 seg... JOJOJO
                  1 sola cosa... ES CHEVROLET :twisted: :twisted: :twisted:
                    :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock:
                    Y uno despues se tiene que subir a su auto :cry:
                      Un polvaso
