CHASSIS
Frame / Manufacturer custom by Moal Inc. (Oakland, CA)
Wheelbase 110"
Chassis plumbing stainless steel
Rearend / Ratio Strange Engineering (Morton Grove, IL) 9" / 3.73 limited-slip
Rear suspension Moal-built torsion bar
Rear brakes Wilwood (Camarillo, CA) calipers, 10 1/2" rotors
Front suspension Moal-built torsion bar
Front brakes Wilwood (Camarillo, CA) calipers, 10 1/2" rotors
Master cylinder CNC (San Diego, CA) two, single reservoir units
Steering box Saginaw by Lee Manufacturing (Sun Valley, CA)
Wheel covers '53 Olds
Front wheel make, size steel, 6x15"
Rear wheel make, size steel, 10x15"
Front tire make, size Coker, 185/70R15
Rear tire make, size BFGoodrich, 255/70R15
Gas tank Fuel Safe (Bend, OR) fuel cell
ENGINE
Make Chevy built by Tom Walsh (Danville, CA)
Displacement 355ci
Machining / Assembly S&S Automotive (San Leandro, CA) / Tom Walsh
Crankshaft steel Chevy
Rods Chevy Pink
Pistons / Rings JE Pistons (Huntington Beach, CA) / Total Seal (Greenland, NH)
Camshaft COMP Cams (Memphis, TN)
Water pump cast iron Chevy
Cooling fan SPAL (Des Moines, IA) 16" electric
Radiator Mattson's Radiator (Stanton, CA)
Alternator Enos Custom Components (San Luis Obispo, CA)
Heads cast iron Chevrolet
Valves / Springs COMP Cams
Rockers Chevrolet
Valve covers Corvette 7-fin, chromed/painted
Manifold / Induction Hilborn EFI (Aliso Viejo, CA)
Ignition / Wires Joe Hunt (Rancho Cordova, CA) / Taylor (Grandview, MO)
Ignition box MSD Ignition (El Paso, TX)
Headers cast iron Chevrolet Ram's Horns
Mufflers Flowmaster (Santa Rosa, CA)
TRANSMISSION
Make Tremec (Farmington Hills, MI) five-speed
Clutch / Flywheel Centerforce (Prescott, AZ)
Shifter custom by Moal
Driveshaft Drive Line Service
BODY
Body style / Material Ford roadster / steel
Body manufacturer Brookville Roadster (Brookville, OH)
Hood Moal Inc.
Grille Brookville Roadster
Bodywork Vintage Color Studio (Concord, CA)
Bodywork by Moal Inc.
Paint type / Color PPG / red
Painter Darryl Hollenbeck
Pinstriping Rory (San Ramon, CA)
Headlights / Taillights Harley-Davidson / '50 Pontiac by Bob Drake Reproductions (Grants Pass, OR)
Outside mirror Bob Drake Reproductions w/ Moal stands
Other body items rocker panels, wheelwell panels, steel floor panels all custom by Moal Inc.
INTERIOR
Dashboard '40 Ford
Insert / Gauges '40 Ford / Classic Instruments (South Boyne City, MI)
Wiring Curt Hill of Moal Inc.
Steering wheel '40 Ford billet by Juliano's Interior Products (Vernon, CT)
Steering column '40 Ford by Lime Works (Whittier, CA)
Interior mirror Bob Drake w/ Moal stands
Upholsterer Sid Chavers Fine Auto Upholstery (Santa Clara, CA)
Material / Color Naugahyde / white w/ red piping
Carpet black loop
Seatbelts black by Sid Chavers
