ENGINE
TOYOTA FORMULA ATLANTIC 4AGE ENGINE
250HP / 148 ft/lb
Displacement : 1600 CC 13.5 TO 1 C/R
Stroked : 81MMX77MM
TRD ATLANTIC IN 278/11MM EX 272/10.5MM cams
MAHLE 81MM Pistons
TRD valves
TRD valve springs
Pectel T6 ECU
Bosch 803 injectors
TRD Atlantic ITB's
Coast Fabrication exhaust
Hasslegren Racing header
Hasslegren Racing cam gears
BOSCH F2CS spark plugs
Fluidyne radiator
Hasslegren Racing 3-STAGE DRY SUMP SYSTEM
TRD racing transmission
CUSCO 2-WAY LSD
SUSPENSION
H&R coilover front springs
TRD rear springs with GAB shocks
ADDCO front and rear swaybars
TRD bushing kit
Impact Engineering steering rod and control arms
BRAKES
Mazda FC front brakes
Custom 12 inch rotors
HAWK HT-10 brake pads
Goodridge brake lines
WHEELS/ TIRES
Sportmax Wheels
Toyo TI-R 195/50/15 tires
EXTERIOR
JDM Kouki bumpers
JDM fender lamps
JDM Kouki coupe tail lights
INTERIOR
Recaro Pole Position seats
NARDI steering wheel
Hasselgren Racing shift knob
Tilton floor mount pedal set
Safety 21 roll cage
Pioneer headunit
JL speakers
fuente nipponpower.com.mx
si es prepost reporten
250HP / 148 ft/lb
Stroked : 81MMX77MM
MAHLE 81MM Pistons
TRD valves
TRD valve springs
Pectel T6 ECU
Bosch 803 injectors
TRD Atlantic ITB's
Fluidyne radiator
CUSCO 2-WAY LSD
SUSPENSION
TRD bushing kit
BRAKES
WHEELS/ TIRES
Sportmax Wheels
EXTERIOR
JDM Kouki bumpers
JDM fender lamps
INTERIOR
Safety 21 roll cage
Pioneer headunit
JL speakers
