![](http://image.popularhotrodding.com/f/9117811/0707phr_01_z_+1971_ford_torino+.jpg)
![](http://image.popularhotrodding.com/f/9117856/0707phr_05_z+1971_ford_torino+.jpg)
![](http://image.popularhotrodding.com/f/9147600/0707phr_12_z+1971_ford_torino+.jpg)
![](http://image.popularhotrodding.com/f/9117910/0707phr_11_z+1971_ford_torino+.jpg)
![](http://image.popularhotrodding.com/f/9117958/0707phr_17_z+1971_ford_torino+.jpg)
![](http://image.popularhotrodding.com/f/9117967/0707phr_18_z+1971_ford_torino+.jpg)
![](http://image.popularhotrodding.com/f/9117946/0707phr_16_z+1971_ford_torino+.jpg)
![](http://image.popularhotrodding.com/f/9117820/0707phr_02_z+1971_ford_torino+.jpg)
![](http://image.popularhotrodding.com/f/9117901/0707phr_10_z+1971_ford_torino+.jpg)
![](http://image.popularhotrodding.com/f/9117841/0707phr_04_z+1971_ford_torino+.jpg)
![](http://image.popularhotrodding.com/f/9117832/0707phr_03_z+1971_ford_torino+.jpg)
![](http://image.popularhotrodding.com/f/9147591/0707phr_09_z+1971_ford_torino+.jpg)
![](http://image.popularhotrodding.com/f/9117862/0707phr_06_z+1971_ford_torino+.jpg)
UN AUTO QUE LO USAS TODOS LOS DIAS Y METE 11:04
![Aplauso](https://foro.enfierrados.com/core/images/smilies/aplauso.gif)
71 Ford Torino GT: $2,600 (in 1987)
Paint & body: $5,000
Mini-tubs: $0
Wheels: $400
Tires: $500
Engine block: $400
Rotating assembly: $1,150
Rings & bearing: $150
Machining: $500
Cam: $140
Lifters: $120
Pushrods: $75
Used rockers: $120
Timing set: $20
Cylinder heads: $1,800
Used intake manifold: $200
Used carb: $400
Stock distributor: $40
MSD ignition box: $180
Plug wires: $70
Used oil pan: $100
Oil pump: $120
Gaskets: $110
Used headers: $200
Mufflers/collectors: $120
Used fuel system parts: $300
Radiator: $125
Water pump: $180
Cooling fan: $40
Trans: $1,300
Torque converter: $400
Shifter: $100
Rearend build: $670
Rear shocks: $20
Rear springs: $0
Rear sway bar: $10
Front suspension rebuild kit: $140
Vinyl seat dye: $30
Auto Meter tach: $110
Oil/volt/temp gauges: $30
Rollbar: $1,500
Five-point harnesses: $400
Total: $19,870
