estos son los datos del auto STD... para el que no lo conoce, es integral, turbo IC y toda la bola
length - 3975mm
width - 1690mm
height - 1410mm
wheelbase - 2430mm
curb weight - 1220kg
maximum speed - 223kph+
accelleration 0-100kmph - 5.9 seconds
accelleration 0-400m - 13.9 seconds
engine model - SR20DET
engine type - turbocharged inline four, dohc, 16 valves, intercooler
max power output - 227hp @ 6400rpm (or 171.5 kw)
max torque - approx. 290 nm
compression ratio - 8.3:1
turbo - Garret TB2804 (T3/T25 combination)
control system - electronic port injection
transmission type - 5 spd manual
suspension - 4 wheel independent with front macpherson struts, rear parallel links
4wd system - ATTESSA with viscous coupling centre diff and viscous LSD
brakes - vented front and rear
ABS - A4 sensor, 2 channel electronic anti-lock
este auto tiene modificaciones, en embrague, suspension, admision y algunas cosas mas..
aaaaa y el 32/34 laburado
length - 3975mm
width - 1690mm
height - 1410mm
wheelbase - 2430mm
