HKS Zero-R
  • HKS Zero-R
    2006 is the year of a true comeback. The extremely rare, limited edition BNR32-based HKS Zero-R has been re-released sporting a fully re-engineered engine, transmission and suspension. Could this be the ultimate street-going GT-R? The history of this unique car starts back in the early '90s when HKS' headquarters in Japan decided to do what tuning shops such as RUF where doing in Germany, and that is create bespoke high-performance streetcars. The project started with four cars being built. However, when the time came to register them as one-off models not tied with the Nissan brand, the problems began. Due to Japanese legislation at the time, HKS was required to crash test a number of cars in order to obtain road homologation. HKS decided to abandon the project as it would have proven too expensive, totaling Y13,000,000 ($116,400) per car. In the end, HKS kept three of the cars. The fourth was purchased by the Sultan of Brunei, who had it shipped home to join his extensive collection of exotic cars.
    It wasn't until last year that HKS decided to bring back the Zero-R. This was possible thanks to slightly more lax legal procedures that would allow HKS to register the car as a modified Nissan Skyline R32 GT-R. When HKS announced this via a small feature article in an issue of the Japanese GT-R Magazine, the phone calls began. The job of bringing the car back into life, and of creating it in line with modern performance expectations, was given to HKS Technical Factory in Tokyo. As Mr. Kikuchi, president of the workshop explains, the 450PS and 50 kgm developed by the original cars just wasn't going to cut it in today's market. The now obsolete TA45S single turbine needed to be replaced and every other technical aspect of the car looked at in order to guarantee the best possible result.
    The silver car you see here is the first Zero-R to be registered in Japan, now owned by a GT-R-crazy doctor in Kobe. This was the first of the three cars HKS had left to be converted into "modern-day" specifications. It all started with the engine. The old RB26 was scrapped and replaced by the finest performance parts currently available. Basing the build on a limited edition Nismo GT-block, it was already bored to accept the fully forged and balanced HKS 2.8-liter kit. Thus the final product would guarantee ample durability and strength seeing that this block was the same thick-walled item used on all RB powered GT-500 race cars from the JGTC championship (now called Super GT).
    The extra 200cc in capacity would help achieve the goal of creating a motor that is powerful but responsive, with bucket loads of torque at any rpm. Compression was slightly increased to 8.7:1 while a lot of work went into preparing the head for optimal breathing performance, with fully ported and polished intake and exhaust ducts as well as full HKS valvegear. For best real-world performance it was decided to use the recently released HKS V-Cam System, which introduces programmable variable valve timing on the intake side. As both drivability and durability were the main objectives for HKS, it was decided to use a set of GT2530 turbines. These allow the Zero-R to crank out 600 PS at 7,400 rpm, and - thanks to the combined hike in capacity and V-Cam System - a mighty 66 kgm at 4,400 rpm. These are figures GT-R owners would have only dreamt about 10 years ago, especially if you take into account the progressive power delivery and virtually flat torque curve from 3,000 rpm all the way to 6,000 rpm.
    Juggling all this twisting force is a Nismo Coppermix clutch, which is as easy to use as a stock factory unit and sends drive to the Getrag 6-speed transmission. No, that's not a misprint - HKS has replaced the Nissan 5-speeder with the BNR34 box. The final drive is now 3.9, and is perfectly matched for the electrifying performance of the revamped RB.
    Sitting in the HKS factory for over 10 years can take its toll on the suspension. With this in mind, HKS stripped down every component from under the car - including the sub-frames, and replaced all bushings, links and suspension arms - with Nismo parts. This sharpened up the steering and the handling to offer a more aggressive geometry; and will work beautifully for days at the local circuit. A special custom version of the HKS Hyper Max II coilover kit was fitted specifically for the Zero-R. Braking needed to be addressed too, as the old AP Racing calipers, although still pretty good, just didn't offer the same performance as modern set-ups. So in went 6-pot AP Racing calipers at the front, while the rear is balanced with some 4-pots - again from AP Racing. These both bite down on grooved discs with Performance Friction pads.
    The exterior of the Zero-R has been left untouched - a testament that the original BNR32 design has stood up to the test of time. Within the dress-up, the Zero-R sports a complete body conversion made up of a vented front bumper, chunky side skirts and an aggressive rear-end - courtesy of the twin-exit exhaust system, which peeks its thick tail pipes out of a vented shroud. The exhaust is, in fact, the reason why the Zero-R has no rear seats. Since a lot of space was needed to somehow fit the two rear silencers, the fuel tank was removed and custom mounted where the stock rear seats would be. This might not be such a great idea, as you are actually putting a great deal of weight high up in the car's chassis. However, there is no arguing that the rear end conversion looks superb. The original Italian Tecnomagnesio wheels were specially designed and built for the Zero-R; so the owner decided to keep them on, albeit ten years later, for the complete look. The interior has been mostly left untouched, aside from the rear fuel-tank enclosure.
    On the original Zero-R, two reclining Recaro seats replaced the stock items. However, on this particular car the owner has just fitted a BNR34 seat on the driver side, which he is trying out for a bit before making his final selection on seat choice. Ahhh, must be nice to have money. Gauge-wise, the 360 km/h rated speedo and other meters have been left untouched; and are now joined by a host of modern toys like a set of Defi gauges, the HKS Black Limited EVC boost controller, HKS torque split controller and the HKS V-Cam unit. To keep an eye on Kobe's traffic, an Alpine hard-disk navigation system takes center stage in the interior; while small details like the HKS shift knob and HKS Zero-R original steering wheel finish things off.
    But, no matter how many promises and talk of numbers or power curves, there is nothing like taking a car for a drive to find out what it's really like. Could this be the ultimate street GT-R? Wishing to find an answer we kindly accepted the keys to the Zero-R from Mr. Kikuchi, who let us take the car for a very memorable drive. It's special to drive a Zero-R: there are only two on the road in Japan, and the latest modifications have transformed it into a spectacular ride. As with every 2.8-liter GT-R, you feel the extra capacity the instant you get on the gas. The engine feels gutsier and more willing to pull at lower rpm. But, the Zero-R has a few tricks up its sleeve thanks to the V-Cam. This little gadget maximizes engine breathing continuously, boosting power and torque at every engine speed; but it's from 2,500 rpm and 6,500 rpm that you really feel it work.
    GT2530s might be one of the smallest turbine kits you can put on an RB26; but on a 2.6-liter engine without variable valve timing, they always feel very laggy until about 4,500 rpm when they begin to generate some real boost. On the Zero-R they come into play at 3,000 rpm with well over 1 bar of boost available. Out on the streets, this translates to immediate acceleration no matter what gear you're in. But it's when you really tap into those 600 PS that the Zero-R begins to fly. Despite the maps on the HKS F Con V-Pro not being fully refined yet, there is an impressively smooth and unrelentless power delivery. Needless to say, 600 PS is a hell of a lot of power; and it's almost comical when you look at the needle on the speedometer rise. The BNR34 Getrag transmission feels just perfect with a nice and tight shift pattern making the best of all the engine's capabilities. The AP Racing brakes offer a strong bite at any speed, just make sure you look in the rearview mirror before jumping on them.
    HKS has definitely made one of the most impressive GT-Rs out there. Sure there are more powerful ones, but finding such widespread electrifying performance is not as easy. Having accessible power in any gear and at any speed is precisely what makes the Zero-R such an exhilarating drive. The most ultimate GT-R ever? We certainly think so.
    feo el pobre...
    Re: HKS Zero-R
    que autos q tienen los japoneses...estamos tan lejos
    alguien seria tan amable de traducirme mas o menos los datos tecnicos de ese auto?
      Re: HKS Zero-R
      el Mitico Zero R, el tan mitico que con 600HP palizeaba autos de 800 incluso 900 hp en la wangan
        Re: HKS Zero-R
        exacto y a autos con chasis mas radicales y especialmente adaptados a la competicion tambien los cagaba a palos de arribaa abajo.
        yo me pregunto: nunca vamosa poder a desarrollar autos como los locos estos? con esas tremendas bases japonesas?
        que lindo seria
          Re: HKS Zero-R
          que lindo seria
          Para que, si un 147 anda mas rapido....
          Aca si no haces el tiempo de la 7 sos un muerto, y para andar rapido en el 1/4 que mejor que el 147...
            Re: HKS Zero-R
            zarpado!!! una belleza!
              Re: HKS Zero-R
              muy lindo, tengo una revista gallega donde este año probaron el nuevo gtr (skiline), y decia que sacando inglaterra es la primera vez que tienen skiline en europa, obvio no me sorprende que aca no este.¿Alguien sabe algo en CASTELLANO del auto?
                Re: HKS Zero-R
                tenes toda la razon corolla, para que carajo nos vamos a complicar no?
                  Re: HKS Zero-R
                  Hablaran del modelo nuevo, porque en alemania hay bastantes
                    Re: HKS Zero-R
                    En una parte de la revista hablaron un poco de la historia del skiline (5 versiones creo, no recuerdo) y decia que solo se vendio en inglaterra ,no tenia volante a la izquierda.En rapido y furioso sale uno , y en la tele vi que en usa lo modificaban,lo adaptaban!! es solo lo que lei,y del nuevo seguro se vende en varios paises
                      Re: HKS Zero-R
                      Si, creo conocer al skyline...
                      el Skyline tiene mas de 25 versiones, se venden desde 1960.
                      Y en alemania hay varios
                      Edit: http://www.gtr.co.uk/forum/102737-fo...-r32-gts4.html ahi tenes uno en venta en alemania, un R32..( 1997 app)
                      OSea hace mas de 11 años que esta ahi.
                        Re: HKS Zero-R
                        mas de 25!!! ni enterado, yo nomas digo de la revista automovil lo que lei, hablaba de muchas menos versiones, sera que nombro las deportivas, con un par de datos sobre c/u,eran pocas versiones las que figuraban.Igual le presta atencion a ese auto desde el gtr
                          Re: HKS Zero-R
                          en japon tambien vienen con volante a la derecha
                            Re: HKS Zero-R
                            No hay version NO deportiva del Skyline.
                            Skyline GTR hay desde 1960...
                            Mucho fan gracias a 2F&2F
                              Re: HKS Zero-R
                              en japon son todos volante a la derecha como en inglaterra, por eso lei que el skyline se vendio en inglaterra
