SportQuattro "Pikes Peak"
  • SportQuattro "Pikes Peak"
    There is one nice story about Pikes Peak. When Audi came to the first qualifying session with the Batmobile, the Peugeot guys were laughing their head off: One would never need so much wings on a Pikes Peak car! Man, were they wrong: after the first session they were at first shocked and then very busy. They called the development center in France to get such wings as fast as possible. Well, Audi had done excessive windtunnel testing for months. Peugeot now was trying to overcome this advantage by working around the clock. And what is the fastest way to get things from Europe to the U.S. of A.? Right, the Concorde. She had to fly several times a day! Not very cheap, huh? Nevertheless, Peugeot had to wait till '88 to get their first win!
    Here you can the front double wing. And the air intake in front of the rear wheel wells. On the eft side of the car, a small oil cooler is behind this opening, whereas on the right side the inlet is actually closed (thanks to Kay for telling me). The wings not only create downforce, they also lessen the house-wall like aerodynamic of the Sportquattro.
    Here you can see the rear double wing, below it the air outlet of the rear mounted radiators (like the normal Rallye S1). If you look carefully you can see the ventilation openings for the wheel wells.
    Here one can see the air outlet for the air that has streamed through the engine compartement (on the hood). Also visible are the outlets for the front wheel wells. Especially interesting is the air intake on the roof. It leads to the rear mounted water and oil coolers. Generally intake have to be positioned in areas of high pressures, outlets should be where the pressure is rather low. While this is accomplished for the outlets here, fans support the air stream for the big radiators in the back.
    This is the heart of it all. In the background you can see the insulated or, to be precise, the wastegate valve. In the foreground you can see the intake manifold and the big pipe that transports the compressed air from the intercooler to the engine. The construction of these parts is poretty important as all cylinders have to get the same amount of air and you do not want to lose to much of the pressure.
    Behind the grill you can see the intercooler, which cools the air that has been heated through the process of compressing. To better its efficiency, it is water cooled. However not as in modern cars with a colsed cooling circuit. Nozzles spray water on it. The water evaporates and drains the heat from the cooler and thus the air, too.
    Here you can see the guiding air fences on the front fenders that probably should prevent that the air flow on the surface gets turbulent. On the back of the car you can see the air intake into the wheel wells and the outward wing plate. it looks as if this plate has the task to "bundle" the airstream. And you can see that the wheel arches of the front fenders are rounded inwards.
    Pretty many aerodynamic tools on car that is surely fast but slower as closed circuit racers. And additionally, the air flow often does not come from straight ahead.
    But that is the way the Peugeot crew members thought...
    ...till the first training.
    la verdad de estetica no me gusta pero tiene alto burraje
    EL NEGRO [vampire]
      opino igual que negrosp....de afuera es un pedo en la cara....el corazon late que te hace olvidar lo feo que es!!! es como un bagarto que garch....como los dioses...jajajaj (no empiecen ahora con que nunca les paso!!!! [ZzZ] )
        Es horible pero tiene mucho power y el que maneja muchisimos huevos para poner el auto de costado en esas barrancas :shock:
          los pilotos que manejaron ahi tienen perfil suicida!!!
            No me gusta mucho, se zarparon con los alerones y faldones que le pusieron...
              uyy que caño, una ves en a todo motor pasaron el video y me quede re loco como manejan y como acelera eso!!
              Esta terrible
                Me parece q se los pucieron porque son necesarios
                  MIRA LO Q ES LA PISTAAAAAAA
                    Decime UN solo coche de Pikes Peak que no tenga esa carga aerodinámica.
                    Sin eso como ponés 700hp en la tierra y lo mantenes de costado en una curva a 200km/h agarrado al piso.
                    Igualmente el 205 T16 y el 405 T16 son los zarpados en la materia. :twisted:
                      [quote="Ellobo"]
                      Lobo buscate algun video del Suzuki que le saco el record al 405 y si el de Ari Vattanen parece suicida no te podes imaginar lo que es la cosa esa de fibra con 999hp a fondo :shock:
