Otra de las cosas raras que me gustan
General Information
Make Peugeot
Model 504 V6 Coupe
Production Year 1974
Country
Designer Pininfarina
Production Number
Model Code
Model Family
Chassis and Dimensions
Chassis Type 2+2 FHC
Number of Doors 2
Wheelbase 2550 mm (100.4 in)
Front Track 1490 mm (58.7 in)
Rear Track 1430 mm (56.3 in)
Length 4360 mm (171.7 in)
Width 1700 mm (66.9 in)
Height 1350 mm (53.1 in)
Ground Clearance
Length / Wheelbase Ratio 1.71
Weight 1270 kg (2797.4 lb)
Weight Distribution (front/rear)
Fuel Capacity
Aerodynamics
Drag Coefficient
Frontal Area
Cx
Engine Specifications
Engine Manufacturer Renault
Engine Location Front
Engine Alignment Longitudinal
Engine Construction
Coolant Type Water
Engine Type SOHC
Number of Cylinders and Placement V-6
Valves per Cylinder 2 (toplam 12 adet)
Engine Displacement 2664 cc (162.57 cu in)
Bore 88 mm (3.46 in)
Stroke 73 mm (2.87 in)
Bore / Stroke Ratio 1.21
Unitary Capacity 444 cc/cylinder (27.09 cu in/cylinder)
Number of Main Bearings 4
Compression Ratio 8.65 : 1
Fuel System Type 2 So carbs
Aspiration Type Normal
Compressor Type -
Intercooler Type None
Catalytic Converter No
Maximum Engine Power 136 HP (101.4 kW)
Maximum Engine Power rpm 5750 d/d
Maximum Engine Torque 207 N.m (152.8 lb.ft , 21.1 kg.m)
Maximum Engine Torque rpm 3500 d/d
Engine Torque at Max. Engine Power rpm 168.4 N.m (5750 d/d)
Power / Weight Ratio 107.1 HP/ton (79.9 W/kg)
Power / Engine Displacement Ratio 51.1 HP/litre (38.1 kW/litre)
CO2 Emissions
Fuel Consumption
Performance
0 - 80 km/h
0 - 60 mph
0 - 100 km/h 10.5 s
0 - 160 km/h
80 - 120 km/h (in top gear)
0 - 400 m Acceleration 17.1 s
0 - 1000 m Acceleration
Top Speed 186 km/h (115.6 mph)
![](http://www.autogaleria.pl/tapety/img/peugeot/peugeot_504_coupe_1977_01_m.jpg)
[img width=700 height=525]http://peugeot.mainspot.net/pics/pic103.jpg[/img]
General Information
Make Peugeot
Model 504 V6 Coupe
Country
Production Number
Model Code
Model Family
Number of Doors 2
Ground Clearance
Fuel Capacity
Aerodynamics
Drag Coefficient
Frontal Area
Cx
Engine Construction
Coolant Type Water
Engine Type SOHC
Compressor Type -
CO2 Emissions
Fuel Consumption
Performance
0 - 80 km/h
0 - 60 mph
0 - 100 km/h 10.5 s
0 - 160 km/h
