Inside At Ford Racing: Building a 2014 Cobra Jet Engine
by Jason Reiss
posted on Sep 3, 2013 in Engine
One of the perks with holding down a position here at StangTV is that we get to see all sorts of inside information that we’re then tasked with bringing to you, our faithful readers. This time around, we were invited to see what goes into creating one of Ford Racing‘s Cobra Jet engines, with photography and an inside look through what goes into creating the heart of one of the most successful “factory” racing programs around. Although the Cobra Jet program doesn’t provide free racecars to anyone, if you’re lucky enough (and financially liquid enough) to get onto the build list, you’ll be receiving one of the most well-engineered platforms designed specifically for NHRA Stock and Super Stock racing that’s ever been constructed.
The Cobra Jet program came to light back in 2008, with the first cars rolling off the assembly line and virtually right into the winner’s circle in the hands of the Brent Hajek-owned, John Calvert-driven CJ at the 2009 NHRA Winternationals. Since then, the Cobra Jet has become the winningest late model in NHRA, including national event wins in 2009, 2010, 2011, and 2012, class wins at the 2011 U.S. Nationals, and a top ten finish with Bo Butner in Stock Eliminator in 2011. In addition, the Cobra Jet’s performance on-track had a big hand in Ford winning the 2011 NHRA Manufacturer’s Cup, as the national event win coupled up nicely with three runner-ups, four semi-final appearances, and 16 number-one-qualifier spots during the course of that season. Past versions of the Cobra Jet were outfitted with a 5.4-liter supercharged engine, but with the 5.0 returning to its rightful place between the fenders of the Mustang, the decision was made to outfit the factory race car with the current powerplant.
Keeping tolerances held in check is critical to the Cobra Jet engine program. Each part is measured in the climate-controlled engine building facility prior to installation to ensure durability in the demanding conditions these engines face.
Winning Formula
Naturally, when the gang from Ford Racing asked if we wanted to check out a build on the 2014 Cobra Jet 5.0L engine, we jumped at the opportunity to see what goes on behind the scenes at Ford Racing. The supercharged mill we followed features the latest and greatest in Coyote engine development, complete with a Ford Racing/Whipple 2.9L supercharger. The engine also uses the CNC port-matched manifold and cylinder heads in an effort to make the greatest amount of horsepower while remaining class-legal for NHRA Super Stock and other classes where the CJ competes.
Both Ford Racing and mainstream Ford engineers -best minds within the company, were all involved in the Cobra Jet program. When it came time to develop the Cobra Jet engine, the Ford Racing engineers realized that they already had a perfect base for the powerplant right under their noses – the 5.0L “Road Runner” engine that had been developed for the BOSS 302 variant of the Mustang. The BOSS 302 engine already wears the CNC-ported cylinder heads required to make big horsepower in the Cobra Jet. As the cylinder heads wear a pair of camshafts on each side, valvetrain development was one of the ways the Ford Racing engineers tried to boost horsepower further. In fact, after many hours of research time, it was determined that the 12mm-lift, 260-degree duration intake camshafts already installed in the BOSS would be the perfect complement, which simplifies the process. A new, 290-degree duration exhaust camshaft was profiled.
Top Left - Mahle supplies the pistons for the CJ engine, while connecting rods were sourced from Manley and are the same rod found in the 2003 Cobra, upgraded with ARP2000 capscrews. Top Right - The entire build process is detailed on this computer screen, giving the technician a step-by-step guide to assure each assembly operation is completed. Bottom Left - ATI supplied their Super Damper for the Cobra Jet engine. It drives the supercharger and keeps unwanted engine vibrations at bay. Bottom Right - Completed front dress including the TiVCT computer-controlled camshaft adjusters.
One of the main developments within the 5.0L engine was the introduction of Ti-VCT, which is an adjustable camshaft timing system that’s computer-controlled and offers huge benefits in power, torque, and overall engine efficiency.
We spoke with Ford Racing’s Jesse Kershaw, who explained, “For us Ti-VCT is a way of life, included in many Ford engines. It allows significant gains for both horsepower and torque throughout the powerband. The 5.0L was designed to have it, so we use that capability. I wouldn’t consider it complex necessarily for Ford calibration but it does add more variables that require calibration time and attention. For the aftermarket it can be a major hurdle. Most aftermarket control modules simply lock out the cams for peak power which means they are left to make up for that power under the curve through other means.”
Bottom End
In 2013 Cobra Jet production included 47 supercharged cars and three naturally-aspirated machines. Each aluminum engine block undergoes strict machining processes at Livernois Motorsports before being shipped out to be completed at the Ford Racing facility. The naturally-aspirated engines are sleeved and machined to a 94mm bore size, while the supercharged variants keep the stock bore size of 92.2mm for strength and durability. Although the 5.0L engine was introduced with piston squirters in 2011, they have subsequently been phased out – piston squirters were also omitted from the start on BOSS and Cobra Jet engines.
Left - At the Ford Racing engine building facility, OEM technologies are used to assemble the engine, including the use of pre-calibrated pneumatic torque wrenches. Middle - One of the critical items to keep engine temperatures down is the intercooler, which resides under the supercharger. Right - A fully-dressed supercharged 5.0L Cobra Jet engine awaiting transfer to the Flat Rock facility for installation.
There were a number of other changes that made their way from R&D to the Cobra Jet engine as well. Kershaw said, “We had to upgrade the rods to Manley H-beams from the 2003 Cobra, with ARP2000 fasteners they will safely turn 8,100 RPM. We worked with Mahle to get the piston material, ring location, and weight that was deemed necessary to maintain consistency and durability. We also upgraded the oil pump to a billet gear unit that is tested at the OEM production facility and held to the tightest tolerances. While we have never had an oil pump failure, we added this as an extra margin of safety for our customers depending on what they plan to do.”
Another area where the Cobra Jet team saw increases in power came from the engine oiling system. According to Kershaw, removing as much windage as possible from the crankshaft netted them another twenty horsepower in the higher RPM ranges. Instead of developing a brand-new oil pan from scratch, they headed to the parts bin and selected the M-6675-M50BR oil pan kit from their road racing program, which helped to give much better oil control, as it implements a windage tray and an oversized oil pan with trap-doors installed to help manage oil flow. Although drag racing is a straight-line endeavor, the road race pan has been used successfully in this application.
by Jason Reiss
<a href='http://www2.powertvonline.com/digitalads/www/delivery/ck.php?oaparams=2__bannerid=8492__zoneid=414__cb=c 6212407d4__oadest=http%3A%2F%2Fwww2.powertvonline. com%2Fdigitalads%2Fwww%2Fdelivery%2Fck.php%3Fn%3Da ebce394%26amp%3Bcb%3D%25n' target='_blank'><img src='http://www2.powertvonline.com/digitalads/www/delivery/avw.php?zoneid=410&cb=%n&n=aebce394&ct 0=%c' border='0' alt='' /></a> |
<a href='http://www2.powertvonline.com/digitalads/www/delivery/ck.php?oaparams=2__bannerid=8492__zoneid=414__cb=c 6212407d4__oadest=http%3A%2F%2Fwww2.powertvonline. com%2Fdigitalads%2Fwww%2Fdelivery%2Fck.php%3Fn%3Da ebce394%26amp%3Bcb%3D%25n' target='_blank'><img src='http://www2.powertvonline.com/digitalads/www/delivery/avw.php?zoneid=410&cb=%n&am;n=aebce394&ct0 =%c' border='0' alt='' /></a> |
Winning Formula
We saw a 60 ft-lbs torque increase at 4300 RPM just by optimizing the cam timing with TiVCT. – Jesse Kershaw, Ford Racing
Perfect TimingOne of the main developments within the 5.0L engine was the introduction of Ti-VCT, which is an adjustable camshaft timing system that’s computer-controlled and offers huge benefits in power, torque, and overall engine efficiency.
Bottom End
