Aggressive STI
  • Aggressive STI
    • Wheels/Tires/Suspension
      Suspension:
      Tein Flex coilovers
      Tein EDFC
      Cobb 24mm rear sway bar
      Kartboy rear end links
      Cusco rear strut bar
      Cusco lower H brace
      Cusco front strut bar
      Cusco rear V-brace
      Ingalls camber bolts (rear)Wheels/Brakes:
      Advan RG-D 18×10.5 +10
      Hankook Ventus Evo 295/30/18
      Girodisc slotted rotors front and rear
      Girodisc titanium brake shims
      Hawk HP-Plus Pads
    • Exterior
      Chargespeed Bottomline 2 kit (sides and rear carbon fiber)
      Seibon carbon front lip
      Carbing Carbon Fiber rear plate housing
      Perrin wing stiffies
      Carbon fiber rear window wing
      Karlton Fender Flares
      HKS/Kansai Carbon Fiber rear diffuser
      APR Carbon GT Mirrors
      APR Carbon canards
      Blacked out headlights
      JDM 04/05 Tail Lights
    • Interior
      Bride Brix II seats and rails
      Bride rear seat
      Arai Motorsport Carbon Fiber door cards. (Only LHD set ever made)
      Carbon Fiber door sills
      Werkshop Carbon Fiber center console
      Werkshop Carbon Fiber vent rings
      JDM Red Hazard button
      Sparco 3” 4 point harnesses
      Sparco Harness Bar
      STI black floormats
      Prosport Boost Gauge
      Prosport Oil Pressure Gauge
      Innovate Motorsports Wideband AFRBlox Iridium 16oz shift knob
      JPM Coachworks Alcantara shift boot
      JDM DAMD D-Shaped Steering Wheel
      Pioneer AVH-P8400BH Touch Screen Head Unit
      Polk 5.25″ 2 way coaxial speakers front and rear
    • Engine
      Element Tuning GT52 turbo
      Injector Dynamics 2000cc Injectors
      CP 100mm pistons
      ACL rod bearings
      Manley I beam rods
      Darton Big Boy sleeves
      LIC Motorsports adjustable idler pulleys
      Killer B oil pickup
      ARP head studs
      Perrin 2.4” turbo inlet
      Perrin 4bar MAP sensor
      Turbo XS FMIC
      Tial 50mm BOV
      EQ TGV Deletes
      EQ Baffled Air/Oil catch can
      EQ Blow through maf setup
      EQ Air Pump Block Off Plates
      Hallman MBC
      Custom short ram 3″ Intake
      Aeromotive Fuel Pump (E85 Compliant)
      Golan in-line fuel filter (E85 Compliant)
      Cobb AP v2.0
      Tomei EL Headers
      Invidia Catless DP
      Tomei Full Titanium exhaust
      Cosworth Billet timing belt guide
      Killer B alternator cover
      Killer B radiator shroud
      B-Line Motorsports top mount oil cooler
      Koyo Aluminum Radiator
      E85 Speed Density full tuneDrivetrain:
      RPS Street Max clutch
      ACT Street Lite flywheel
      STI Short Shifter linkage
      Kartboy Short Shifter
      Kartboy Shifter bushing kit (front and rear)
      STI Group N engine mounts
      STI Group N transmission mount
      Whiteline Steering Rack Bushings
      Whiteline Rear Differential Bushings
      Beatrush Pitch Stop Mount
      Cusco Master Cylinder Brace
    • The STI boasts an impressive 293hp, delivered from a 2.5 liter flat 4 boxer, connected to a 6 speed manual transmission. Well, Matt wasn’t satisfied with the stock specs, and over the 6 years of ownership he has transformed his Subaru into a monster, pushing 422hp to the wheels. The spec list under the hood is insane; everything has been upgraded, from the pistons, to the turbo, fuel system, and drivetrain.Matt built up the STI’s block with CP 100mm pistons and Darton Big Boy sleeves, to ensure that the added power from an Element Tuning GT52 turbo would not cause any (more) issues in the future. Clean air is routed through a custom 3” short ram intake, and is cooled via a Turbo XS front mount intercooler. As for exhaust, Matt went with an Invidia catless downpipe, Tomei EL headers, and a Tomei full titanium exhaust.
    Re: Aggressive STI
    Uffff!! Que hermoso que esta eso papaaa!! paso horas mirando stancenation a veces... siempre tremendos caños!
      Re: Aggressive STI
      Terrible auto, me encanta. Igual los 422hp son "pocos", hay preparaciones de 600-700hp.
      Enviado desde mi XT890
        Re: Aggressive STI
        excelente auto, lo que si asqueroso lo que hicieron con el CAI y mas que nada con esa toma de caño corrugado naranja, en que estaban pensando??? ajajaja
          Re: Aggressive STI
          uuuf, el mejor que vi hasta ahora.
            Re: Aggressive STI
            Tremendo! hoy me paso uno en la ruta, el de luces redonditas, que hermoso sonido!
            Que exageracion el ancho de las gomas.
              Re: Aggressive STI
              Que hermosura, como me vuelven locos esas butacas bride diooos
                Re: Aggressive STI
                che q jodido esto eh...
                  Re: Aggressive STI
                  dios q lindo!
                    Re: Aggressive STI
                    Le saca la calco de Advan y lo termina.
                      Re: Aggressive STI
                      Me cagaste el dia ... por dioss que auto hermoso !!
                        Re: Aggressive STI
                        Que belleza ese baru, me volo el marote
                          Re: Aggressive STI
                          motor 2.5 y una gt52 y solo 400 burros?, lo debe usar con 10 psi
                            Re: Aggressive STI
                            que polvo, es perfecto...
                              Re: Aggressive STI
                              Porno, la puta madre que me parió.
