Up front, the original subframe was blasted clean, powdercoated, then treated to Hotchkis tubular upper and lower A-arms combined with SSBC 2-inch dropped spindles complemented by QA1 adjustable coilover shocks. Out back, a Strange 12-bolt rear filled with 3.73:1 cogs is suspended in place by Calvert Racing’s split monoleaf springs and CalTracs traction bars combined with QA1 adjustable coilover shocks. To bring it all to a halt, 11-inch SSBC rotors and calipers reside up front while factory drums get the job done out back. A set of Billet Specialties Street Lite wheels shod with Mickey Thompson Sportsman rubber seal the car’s aggressive stance and demeanor. Now armed with “the look,” and to make sure any stoplight challengers would get their money’s worth, Brett contacted Scott Shafiroff to build a pump-gas friendly beast. One that would leave your guts on the floor once the go-pedal was planted. The result: a 582ci stroked Rat packed with all the endless innovation Shafiroff is known for. The ensemble includes an Eagle crank and rods, JE 10.5:1 slugs, COMP Cams stick, and Dart Pro aluminum heads. A 950cfm Holley sucks air and fuel through an Edelbrock Victor Series intake with spent gasses getting dumped through a set of Hooker headers. Pulling 745 hp on the dyno is enough to peel back anyone’s eyelids and a make scrap metal out of any transmission that’s not quite up to the task. So in went a Coan Extreme 400 Pro trans and B&M Quicksilver shifter to handle the abuse.
Read more: 1969 Chevy Camaro Z/28 RS - Camaro Performers Magazine
