Red Godzilla!!! "NISSAN SKYLINE GT-R R32 91' "
  • Red Godzilla!!! "NISSAN SKYLINE GT-R R32 91' "
    Specs & Details
    '91 Nissan Skyline GT-R
    Engine
    Nissan RB26DET inline-6
    Engine Modifications N1 block, oil pump; Trust extended oil sump; Reimax oil pump; HKS step II 2.8-liter stroker kit, 1.2mm metal head gasket, Dynamic-balanced HKS crank, 272-degree 10.2 camshafts, stainless steel exhaust manifold, T04Z turbine, GT-II external wastegate, intercooler, oil cooler, billet fuel rail, 800cc fuel injectors; high-performance valve guides; re-cut valve seats; polished & ported head; Pro Stock Racing 90mm front pipe & titanium exhaust by Fujitsubo; Pro Stock Racing V-intake pipe, high-flow AFM, collector tank, lightweight radiator fan pulley, oil catch can; Trust Airinx filters; Nismo GT inlet plenum; Bosh Motorsport fuel pumps; Sard adjustable FPR; Splitfire ignition coils; Calsonic radiator w/ Pro Stock Racing air separator tank; Billion power steering reservoir tank
    Engine Management Pro Stock Racing ECU
    Drivetrain BNR34 6-speed Getrag transmission; ARC Magic transmission cooler, differential cooler; Exedy triple plate clutch; balanced flywheel & clutch cover; ATS carbon LSD (f/r); 3.9 final drive
    Suspension Pro Stock Racing track-spec adjustable suspension by Öhlins; Eibach springs 18 kg/mm (f) & 16 kg/mm (r); Full Ikeya formula BNR32 pillow-ball suspension arms & links; Auto Select billet aluminum strut tower bar
    Interior Fully spot-welded stripped and reinforced shell; Pro Stock Racing custom multi-point race rollcage w/side-impact cross bars; carbon-fiber door cards; Recaro racing seat; Takata 4-point racing harness; Nismo Alcantara steering wheel & boss; Racepack data logger; custom carbon instrument panel; HKS boost & exhaust temperature gauges, Circuit Attack Timer, EVC boost controller; custom carbon-fiber center console & switch panel; BNR34 stock gear knob
    Exterior Nismo front bumper w/ intercooler air vents, bonnet grille spoiler, rear lip spoiler; Moonface tow hook; Craft Square carbon side mirrors; Top Secret rear fender finisher
    Wheels, Tires & Brakes Volk TE37 wheels 18x9.5" +15mm (f/r); Yokohama Advan A050 M-Compound tires 265/35R18 (f/r); Brembo Racing forged monoblock racing 6-pot calipers; PFC 2-piece dimpled floating discs (f/r), race-compound brake pads
    Respuesta: Red Godzilla!!! "NISSAN SKYLINE GT-R R32 91' "
    vamo el turbina simple!
      un sueño.........
      quiero una barra estabilizadora asi para el cuarenti ! jaja
        Flojos fierros... Un misil...
          Ni prolijo el tipo ah! muy bueno che....
          Ahora, que alguno de los expertos en JDM me desasne, xq le dicen godzilla al 32?
            This car was nicknamed "Godzilla" by the Australian motoring publication "Wheels" in its July 1989 edition, a name that sticks to this day. The R32 GT-R dominated the motorsport in Japan, winning 29 straight victories out of 29 races. The GT-R proceeded to win the JGTC Group A series championship 4 years in a row, and also had success in the Australian Touring Car Championship winning from 1990–1992, until the GT-R was outlawed in 1993. The Skyline GT-R (R33) was also the first production car to lap the legendary Nürburgring in under eight minutes.
              >Tewngo casco para ese auto!
                Qué hermosura
                  la verdad hermoso!
                    gracias lucho!! sin saberlo, me hiciste el mejor regalito de cumpleaños xD...
                    ON: TRE-MEN-DO!!!!!!
                      Que rara la admision en V que mejoras trae?
                        feliz cumple!!!
                        aca tenes un regalito si te gusta!
                          Belleza... sin palabras.
