1973 dodge challenger - para los mopareros...
  • 1973 dodge challenger - para los mopareros...
    ENGINE
    Type: Chrysler 365ci small-block
    Block: Chrysler block, bored to 4.030 inches
    Oiling: Melling high-volume oil pump, stock pan
    Rotating assembly: stock crank and rods, hypereutectic 11.4:1 KB pistons
    Cylinder heads: Edelbrock Performer RPM with 2.02/1.60-inch valves; Hughes Engines springs, COMP retainers
    Camshaft: COMP solid flat-tappet 244/252 at .050, .554/.576-inch lift, 110-degree LSA
    Valvetrain: COMP lifters, Hughes Engines 1.6:1 rockers, Cloyes timing set
    Induction: Edelbrock Victor intake, 1-inch spacer, BG 750-cfm carburetor
    Ignition: MSD billet distributor, 6AL ignition box, coil, and plug wires
    Fuel system: stock tank; Holley blue pump and regulator
    Exhaust: Hooker 1 3/4-inch long-tube headers, custom X-pipe, dual 3-inch Flowmaster mufflers
    Cooling: stock water pump and cooling fan
    DRIVETRAIN
    Transmission: TorqueFlite 727 trans, Precision Industries 4,800-stall converter, manual valve body, B&M Mega shifter
    Rear axle: Chrysler 8 3/4-inch rearend, 30-spline axles, 3.91:1 gears, and Sure Grip diff
    CHASSIS
    Front suspension: rebuilt stock
    Rear suspension: Calvert Racing leaf springs, custom traction bars, Rancho adjustable shocks, custom subframe connectors
    Brakes: factory discs, front; stock drums, rear; Hurst line lock
    WHEELS & TIRES
    Wheels: Weld Pro Star
    15x6 (1.5-inch backspace), front; 15x10 (4.5-inch backspace), rear
    Tires: BFGoodrich 205/65R15, front; Mickey Thompson ET Street 28x12.5x15, rear
    Best quarter-mile ET: 11.81 at 113 mph
    Respuesta: 1973 dodge challenger - para los mopareros...
    A pesar de que sea uno de los modelos que menos me gusta del challenger, este está barbaro. Te digo mas, le mandas unas llantas bien racing tipo circuito y es para girar en algun circuito tipo Trans Am. Obviamente con la A-833
    Muy buen post.
    ---------- Post added at 21:30 ---------- Previous post was at 21:29 ----------
    esa patente da como para ponerlo en algun chevy... digo por el L78
      naa muy buen aporte hermozo el challenger , pero ya que estamos soñando el modelo 70 con el hemi 426 es el que va.
        no me gusta el color lo demas me re va!
          Un sueño la challenger...
