Curiosos abstenerse! Ignorantes aprendan ;) "DATSUN FAIRLADY Z '74"
  • Curiosos abstenerse! Ignorantes aprendan ;) "DATSUN FAIRLADY Z '74"
    Specs & Details
    '74 Datsun Fairlady Z
    Engine
    RB30 engine block (2,960cc), RB26DETT twin cam head; Rocky Auto custom engine mounts & positioning, 270º camshafts (interior & exterior); HKS adjustable cam pulleys; Solex 50mm carburetors; custom aluminium funnels; Rocky Auto custom throttle linkage & aluminum pivots, 46mm stainless steel 6-into-1 custom exhaust manifold, stainless steel exhaust system; Stagea fuel tank, in-tank fuel pump; Braided fuel lines; Spitfire direct coil packs; Rocky Auto custom radiator, custom oil catch tank
    Transmission
    Nissan R32 Skyline 5-speed transmission; OS Giken close ratio gear set (first 3 gears); ATS carbon clutch; Cusco LSD
    Suspension & Brakes
    Rocky Auto adjustable suspension, solid bushes, custom billet aluminium rear suspension member, billet aluminium links, billet aluminium lower arms, stabilizer bars, custom tubular front subframe, reinforced front struts & engine bay; Nissan R32 Skyline 4-pot front calipers & 2-pot rear calipers; slotted front brake discs
    Wheels & Tires
    Rays Engineering Volk Racing TE37V 15x9" (f), 15x10" (r), Toyo Trampio 205/50R15 (f), 225/50R15 (r)
    Interior
    Rocky Auto spot & seam welded chassis, rollcage; Bride carbon bucket seats; Sabelt racing harnesses; Momo Corse suede steering wheel; dry-carbon door cards; Auto Meter Sport Comp rev counter; Omori Meter gauges: oil temperature, water temperature, oil pressure; Auto Meter fuel pressure gauge, fuel gauge; custom manually operated heating system, centrally mounted battery
    Respuesta: Curiosos abstenerse! Ignorantes aprendan ;) "DATSUN FAIRLADY Z '74"
    lastima el ploter...
      no entiendo la hicieron de carbono y la plottearon?
      me desconcertó, igualmente es una preciosuridad terrible!!
        disculpa por la ignorancia pero es el famoso "eleonora" de la pelicula 60 segundos q no se puede chorear nunca?? (sorry por la pregunta fantaa jaja)
        jajajaj
        ese interior me vuela la peluca 4 vecesssssssssssssssss !!
          jajajaj
          La vas a ligar eh!!!!
          Ploteado o no! me importa un jocara!!! seguro que a un palio con chip y escape le da, no?
            le qeda el ré espacio para un par de caracolitos
              eso es ploteado de aca a la china varias veces...
                Si tuviera el volante a la izquierda yo la usaria...-.
                  una cosa no quita la otra...
                  Yo por ejemplo cuando miro una mina la miro como si yo fuera una mezcla entre brad pitt, george clooney, pirs brosnan,etc,etc,etc. La puedo criticar 100 hora sin parar, pero eso no quita que me la empome igual....
                    Tiene detalles de carbono posta, pero el resto es ploteo en gran escala.
                      Repost, o estoy drogado?
                        Solex 50? Que onda?
                          lo tengo en el Slr 2.2.1 ademas de que esta tambien en el flatout 2 :D :D
                          Jajajaja como me rei con el post qe saltaron qe era eleonora na qe ver xD
                            esta bien pero en algunas fotos esta con "carbono" y en otras negro mate, a eso me refiero.
                              hablo del body, pero te das cuenta porque no tiene profundidad. Ni el 3m te da buena produndidad como la que tiene el roving de carbono
