Engine
* Genesis 427 Side Oiler block
* 4.240-inch bore
* 4.250-inch stroke
* Scat steel crankshaft
* Scat H-beam connecting rods
* Ross forged pistons
* 10.5:1 compression ratio
* Crower camshaft
* Edlebrock aluminum cylinder heads
* 2.25-inch intake, 1.90-inch exhaust valves
* Crower 1.76:1 roller rockers
* Ford Tunnel Wedge aluminum intake
* Two 710-cfm Holley double-pumpers
* MSD distributor, coil, and 6AL ignition
* 657 hp
Transmission
* Top Loader four-speed
* Hurst shifter
Rearend
* 9-inch Ford
* 33-spline axles
* 4.10-gears
Exhaust
* Custom headers
* Flowmaster mufflers
* Side exhaust
Suspension
* Front: Tubular upper and lower control arms, RideTech air springs
* Rear: Triangulated four-link, Ridetech air springs
Brakes
* Front: Lincoln disc, single-piston caliper
* Rear: Mustang disc, single-piston caliper
Wheels
* Front: American Racing Torque Thrust II, 17x7
* Rear: American Racing Torque Thrust II, 17x10
Tires
* Front: Fuzion ZR1, P235/45R17
* Rear: Fuzion ZR1, P275/40R17
Interior
* Custom interior in Torch Red leatherette
Exterior
* Paint by Klamo Garage in Edgewater, Florida; the top is a blend of PPG Metallic Silver and House of Kolor White Pearl, the bottom is House of Kolor Platinum
