Touch aleman! "PORSCHE SPR1R SPORTEC"
  • Touch aleman! "PORSCHE SPR1R SPORTEC"
    Standing still means moving backwards – and that is why it is tradition in the Sportec company to try and make perfection just that bit better. For this reason the 2010 SPR1 R now not only has a traction enhancing four-wheel drive but also several other extras suitable for a race track. Each wheel drive on the SPR1 R can produce 214.5 PS.
    That equates to a not unsporty Golf GTI motorization per wheel and a total performance of a fantastic 858 PS.
    The high revolution 3.6 litre flat twin engine with biturbo charge was in addition equipped with a Smooth Flow air intake with two fuel injection ducts per combustion chamber, titan connection rods, a valved exhaust system, a infinitely variable cam shaft, a carbon Ram Air intake system, a high performance charge-air cooler and two hybrid turbo chargers.
    Each separate part of the motor electronics is calibrated on Sportec’s four-wheel drive engine test bench to the latest conditions. The results of this precision work on the SPR1 R make a top performance of 858 Ps at 8,200/min along with a gigantic torque of 880 NM possible – and that by just 4,800 revs.
    With an optimised start-up high performance clutch, the new four-wheel drive and a limited slip differential the record-breaking performance is ideally brought onto the tarmac. A traction and launch control that can be individually adjusted by means of an “STS” touchscreen unit in the centre console ensures an optimum start.
    Thus equipped the R-model achieves acceleration from 0 to 100 km/h in only 3 seconds. The 200 km/h mark is reached by the motorised understatement in just 8.3 seconds and the 300 km/h limit in 18 seconds.
    Respuesta: Touch aleman! "PORSCHE SPR1R SPORTEC"
    hermosas patasssssssssssss
      858 ps????
          no entendi que tiene que ver el golf gti?
          hermoso bicho
            hermoso bicho
            Segun dice tiene 2 motores :B
              Muy bueno tu ingles!!!!!!
              Compara que tiene la misma potencia en cada rueda que un Golf GTI como dato de "color", recuerden que es tracción integral el 911 Turbo...
              858/4=214.5
                858/4=214.5
                Jajaj taba boludeando ger, por eso la carita esa de los dientes.
                Si ingles tengo, me falto dar el Internacional nada mas
                  hermoso ! ideal para ir a esperanto ! !
                    Cuanta Guerra , Elegancia y Potencia a la vezzz !
                      858/4=214.5
                      me hiciste escupir el monitor.
                      hay videos de esa bestia en accion?
                        que cosa divina!!!
                          Nooo qe lindoooo!!! me encanta
                            jesu maria y la virgen
