Pequeño demonio!!! "HONDA CRX EF7 '89"
  • Pequeño demonio!!! "HONDA CRX EF7 '89"
    Power
    230hp@8,100RPM
    Propulsion
    Custom 1841cc B16B
    SS Work's custom front
    mid-ship engine mounts
    Ported & polished cylinder head
    TODA Racing VTEC Killer camshafts
    TODA Racing valve springs
    JUN titanium retainers
    JUN Super connecting rods
    JUN (Cosworth) forged
    high-compression pistons
    JUN piston rings
    B18C crankshaft
    SS Work's special rocker arm
    SS Work's block brace/girdle
    SS Work's slide-type cam gears
    SS Work's FCR Special intake manifold
    SS Work's "FCR Carburetors"
    SS Work's stainless 70mm
    Racing Special exhaust
    SS Work's stainless 4-2-1 exhaust manifold
    SS Work's distributor
    Holly low pressure-type fuel pressure regulator
    Holly low pressure-type fuel pump
    NGK Iridium spark plugs
    Nagai Denshi spark plug wires
    SS Work's aluminum side-flow
    type 50mm radiator
    YS1 transmission
    Aderia 5-speed cross gear set
    ORC super light single clutch kit
    OS Giken Superlock 1.5-way LSD
    EG6 Civic driveshafts
    Stance
    Swift ID 60mm springs (12k front)
    Ennepetal (Bilstein) shocks
    Cusco carbon fiber rear shock tower bar
    Mugen suspension bushings
    Cusco suspension bushings
    SS Work's pillow tension rods
    SS Work's widened front lower control arms
    SS Work's widened front upper control arms
    SS Work's adjustable rear pillow arms
    SS Work's adjustable upper pillow arms
    SS Work's aluminum rigid stabilizer bushings
    SS Work's pillow stabilizer links
    Resistance
    SS Work's 4-pot front brake calipers
    SS Work's 300mm front brake rotors
    Seidoya GT600 front brake pads
    Seidoya SM400 rear brake pads
    Earl's brake hoses
    Wheels & Tires
    15x8 Advan RG +25 offset (front)
    225/50-15 Bridgestone Potenza
    15x6.5 Rays TE-37 +35 offset (rear)
    195/55-15 Bridgestone Potenza
    Exterior
    SS Work's light blue pearl paint w/GT line
    SS Work's FRP hood
    SS Work's FRP front fenders
    SS Work's F1-look front spoiler
    SS Work's rear diffuser
    SS Work's FRP doors
    SS Work's racing rear hatch
    ARC DTM -Type rear wing (originally made for Mitsubishi EVOIII)
    Mugen side skirts
    SS Work's/Elf graphics
    Interior
    Recaro SP-G seat
    SS Work's aluminum seat rail
    SS Work's one-off aluminum roll cage
    Nardi Classic 360mm steering wheel
    Electronics
    Nagai Denshi multi-mode meter
    Omori mechanical water temperature gauge
    Omori oil temperature gauge
    Omori oil pressure gauge
    [YT]http://www.youtube.com/watch?v=z9rDKblJd_Q[/YT]
    Respuesta: Pequeño demonio!!! "HONDA CRX EF7 '89"
    NAAAAAAAAAAAAAAAAAAAAAAAA me volo la cabeza!!!
      HERMOSOOO, como debe ir eso por dios misil misil
        Me encanta ... debe ser una nave ;)
          repost! encima tuyo
          pero da gusto verlo todos los diass es demasiado guerrero
            Originally posted by lalo_hrc View Post
            repost! encima tuyo
            Es verdad, pero no habia puesto specs y son fotos nuevas!!!
              BRUTAL!!!!!!!!!!!!!!!!!!
              que hermosura de fierro,,, yo creo que eso debe doblar mas fuerte que agarrando una recta---------
                Hay un video que viene tirando con una NSX y el de la NSX recalca lo fuerte que dobla y lo que acelera de abajo!!!
                Sin dudas una CRX de carreras 100%
                  http://www.youtube.com/watch?v=E5hB92SEx80
                    Muyyyyyyyyyyyyyyyyyy bueno!!!
