Engine and Drivetrain
Block '03 Cobra
Displacement 284 ci
Crankshaft Stock '03 Cobra
Rods Stock '03 Cobra Manley
Pistons Manley
Heads Stock '03 Cobra, Ford Racing cam and coil covers
Camshafts Stock '03 Cobra
Intake Stock '03 Cobra, ported lower
Power Adder Kenne Bell 2.2-liter Blowzilla w/Metco 4-pound lower and BilletFlow 3.10-inch upper pulley, Nitrous Express wet nitrous system, Lightning Force Performance heat exchanger, Canton Racing Products reservoir
Throttle Body Accufab
Mass Air 90mm w/custom pipe, DiabloSport MAFia
Fuel System '03 Cobra tank and rails w/Ford GT fuel pumps, Siemens-Deka 60-lb/hr injectors
Exhaust Bassani mid-length headers, Bassani X-shape crossover, Magnaflow mufflers with dumps
Transmission T-56 six-speed w/26-spline input shaft, SPEC Stage 3+ clutch, '99 Cobra steel flywheel, '03 Cobra driveshaft, MGW shifter
Rearend 8.8 w/Ford Racing Performance Parts 3.73 gears, Detroit True-Trac differential, Moser Engineering 31-spline axles, and ARP studs
Electronics
Engine Management Stock w/Kurgan Motorsports SCT X-Cal II tune
Ignition Weapon X coils, NGK Iridium spark plugs
Gauges Auto Meter, Innovate air/fuel
Chassis and Suspension
Front Suspension
K-member PA Racing tubular
Control arms '03 Cobra
Springs Ford Racing "B" springs
Struts Strange Engineering 10-way adjustable
Brakes Stock
Wheels American Racing Torq-Thrust II 17x91/2-inch
Tires Toyo Proxes 245/40
Rear Suspension
Springs Eibach Sportline
Shocks KYB adjustable
Control arms Steeda Autosports uppers and lowers
Brakes Stock
Wheels American Racing Torq-Thrust II 17x11
Tires Nitto 555R Extreme Drag radials
Chassis Stiffening Maximum Motorsports subframe connectors
Once Derek completed the swap, he turned to Bob Kurgan for tuning, resulting in almost 600 hp to the tires on pump gas. At US 41 Dragway, Derek ran the car down the track, resulting in a an 11.37 at 127 mph with an 1.80-second 60-foot time on Mickey Thompson E/T Street radials. With a changeover to Billet Specialties big 'n' littles with Mickey Thompson E/T Drag slicks, that time plummeted to a 10.68 at 132 mph with a 1.51 60-foot.
