The Murcielago is the ultimate performance car and BF make it even more stunning with a whole range of accessories in carbon fibre, leather and stainless steel.
BF Performance, based in Zug, Switzerland, is dedicated to customizing Lamborghinis and customer vehicles at the ''Home of special Lamborghinis'', individualizing and personalizing them to the customer's wishes. As a tuning specialist, BF Performance accentuates the sporty contours and refines both the interior and exterior with various body-styling elements. Racing car flair is created by the lavish use of carbon fibre, lending the Murcielago a fine figure on the track.
At the front end, a carbon fibre front spoiler reduces the lift of the Italian bull. At the rear end of the Murcielago, this task is performed by a diffuser and an efficient rear deck spoiler of the same material. BF Performance adorns the sides with a pair of side sills. Simply fitting these five body-styling elements brings the Murcielago close to the FIA-GT Lamborghini. Further carbon fibre accessories such as the transparent engine bonnet with glass inlay, the exhaust tailpipe cover, headlight covers, boot lid and bonnet and white indicator lights on the side go to complete the sportingly elegant appearance of this 12-cylinder sports car. All the carbon fibre components (including fitting) cost around 30,000 euros. A carbon fibre air box is in preparation.
Carbon fibre also stimulates motor racing sensations on the inside with a 12-piece interior kit. This can be complemented by fitting sports bucket seats and either 4 or 5 point belts, which keep the occupants safely restrained. For those drivers who do not wish to sacrifice any luxury, BF Performance can also fit a multimedia system with a CD radio featuring a fold-out screen and changer, navigation computer, sound system and a rear-view camera to help prevent damage when parking and maneuvering.
BF Performance does not touch the 6.2 l engine. However, in order to match the sound to the visual appearance, BF Performance does offer the option of fitting a sports silencer with the original tailpipes or a competition exhaust for the racing circuit. A brand-new addition to the BF Performance suite is an extravagant tailpipe design, which lends the rear end of the Murcielago a significantly more elegant appearance.
BF Performance can fit wheel spacers for those drivers who find this super sports car too sluggish, enabling the Murcielago to reach its threshold range much later. A positive visual side effect is that the wheels now sit flush with the body. A sports suspension, which promises a further enhancement of handling properties, is in preparation. True to the motto "races are won on brakes", BF Performance also equips this muscle car with a sports braking system, which is composed of four inside-vented 370 mm diameter brake discs and six-piston brake calipers, sports brake pads and brake pipes from steel flex. BF Performance also supplies the sports braking system for Murcielago models pre-dating 2004. By way of an alternative, all the Murcielagos can be equipped with a high-performance braking system from steel or with a high-performance carbon fibre/ceramic braking system.
Fitting composite exclusive wheels enables the Murcielago to almost glide over the tarmac thanks to its light-footed design. They are available for the front in 8.5 x 19 with 245/30 R19 tyres and for the rear in 13 x 19 with 355/25 R19 tyres.
engine 60 Degree, Aluminum Alloy, V12
position Mid Longitudinal
aspiration Natural
valvetrain DOHC, 4 Valves per Cyl w/VVT & VIS
displacement 6192 cc / 377.9 cu in
bore 87 mm / 3.43 in
stroke 86.8 mm / 3.42 in
compression 10.7:1
power 432.5 kw / 580.0 bhp @ 7500 rpm
hp per litre 93.67 bhp per litre
bhp/weight 351.52 bhp per tonne
torque 650 nm / 479.4 ft lbs @ 4000-5400 rpm
redline 8000 rpm
drive wheels Permanent 4WD w/Viscous Traction
body / frame Carbon Fibre Body over Tubular Steel Frame w/Steel Roof & Steel
front brakes BF Performance Cabon Fibre Discs w/6-Piston Calipers
f brake size 370 mm / 14.6 in
rear brakes BF Performance Cabon Fibre Discs w/6-Piston Calipers
r brake size 370 mm / 14.6 in
front wheels F Not Availablealipers x 21.6 cm / 19 x 8.5 in
rear wheels R 48.3 x 33.0 cm / 19 x 13 in
front tire size 245/30 R19
rear tire size 355/25 R19
f suspension Double Wishbones w/Coil Springs, Gas Dampers, Anti-Roll Bar
r suspension Double Wishbones w/Coil Springs, Gas Dampers, Anti-Roll Bar
weight 1650 kg / 3638 lbs
wheelbase 2665 mm / 104.9 in
transmission 6-Speed Manual
gear ratios 2.941:1, 2.056:1, 1.520:1, 1.179:1, 1.030:1, 0.914:1
final drive 2.53:1
