Me parece a mi ... o no existimos ????
FORD GT I
Alcanzan 1181 HP ??
FORD GT II
VIPER I
VIPER II
VIPER III
LAMBORGHINI GALLARDO
El kit para la Gallardo ... no es muy barato no ??
System Contents:
- Engine Removal and Disassembly
- Custom Billet Steel Connecting Rods
- Steel Cylinder Liners
- Custom 9:1 Compression Ratio Forged Pistons
- Polishing of Crankshaft Journals
- Connecting Rod Bearings
- Main Bearings
- Balancing of Rotating Assembly
- Blueprinting and Assembly of Engine
- Heavy Duty Clutch and Pressure Plate
- Twin Water Cooled Dual Ball Bearing Turbos
- Two Tial 38mm Wastegates
- Two Tial 50mm Blow Off Valves
- Custom Made Stainless Steel Turbo Midpipes
- Custom Made Stainless Steel Turbo Downpipes
- Custom Made Stainless Steel Exhaust System
- Stainless Steel Turbo Oil Feed Lines
- Stainless Steel Turbo Oil Drain Lines
- Colder Heat Range Spark Plugs
- High Flow Turbo Air Inlet Plumbing
- High Flow Turbo Air Discharge Plumbing
- Spearco Water to Air Intercooler
- Intercooler Water Pump
- Intercooler Water Reservoir
- All Necessary Lines and Fittings
- High Flow In Tank Fuel Pumps
- Upgraded Fuel Injectors
- All Necessary Gaskets and Fluids
- Optimized Fuel and Spark Calibration
- Professional Installation and Tuning
FORD GT I
Alcanzan 1181 HP ??
FORD GT II
VIPER I
VIPER II
VIPER III
System Contents:
- Main Bearings
