Y de estos si que hay aca!!!
Specs:
Engine
H22A
Hasport mounts
Hondata intake manifold gasket
ARP studs
Samco hoses
Skunk2 Pro Series Stage II cams
Greddy timing belt
Skunk2 Pro Series standard compression valves
Skunk2 titanium retainers
Skunk2 Pro Series cam gears
Walbro fuel pump
K&N air filter
Hytech replica header
A’pexi WP2 exhaust system
MagnaFlow high-flow cat
NGK Iridium spark plugs
MSD 8.5mm plug wires
JDM M2A4 transmission
Clutch Masters Stage II clutch
Fidanza flywheel (8 lb)
Stance
Function Form Type 2 coilovers
Suspension Techniques front/rear antisway bar
Energy Suspension bushings
Eibach Pro alignment kit
Cusco front/rear shock tower bars
Resistance
OEM ’95-’98 Odyssey blank rotors
OEM Legend ceramic pads
OEM Legend calipers
Honda brake fluid
Stainless steel lines
Wheels & Tires
Work VS wheels 17x8 (+30 offset) front, 17x9 (+30 offset) rear
Nitto Neo Gen 215/40-17 front, 215/45-17 rear
Interior
RSX seats
S2000 AP1 steering wheel
Dojo carbon-fiber shift knob
Exterior
VIS carbon-fiber hood
JDM SiR spoiler
JDM SiR front lip
Mugen grille
Work rear lip
Custom paintjob
Specs:
Engine
H22A
Hasport mounts
ARP studs
Samco hoses
Greddy timing belt
Walbro fuel pump
K&N air filter
Stance
Resistance
OEM Legend calipers
Honda brake fluid
Wheels & Tires
Interior
RSX seats
Exterior
JDM SiR spoiler
JDM SiR front lip
Mugen grille
Work rear lip
Custom paintjob
