CHASSIS
Frame - Dodge, boxed rails
Chassis plumbing - stainless
Rearend / Ratio - Ford 8" (Maverick) / 2.79:1
Rear suspension - parallel leaf, Gabriel shocks, drum brakes
Front suspension - Fat Man Fabrications Mustang II-style; dropped spindles, rack-and-pinion steering; 11" disc brakes; Heidt's narrowed control arms
Master cylinder - Corvette dual-circuit; 8" power booster
Front wheel make, size Wheel Vintique Ford-style wires, 15 x 7; 3 3/4" offset
Rear wheel make, size Wheel Vintique Ford-style wires, 15 x 8; 3 3/4" offset
Front tire make, size - BFGoodrich Silvertown radial, 185/70R-15
Rear tire make, size - BFGoodrich Silvertown radial, 205/70R-15
Gas tank - Rock Valley stainless 18 gal
ENGINE
Year and make - '68 Chevrolet Corvette
Displacement - 350ci
Camshaft - Comp Cams RV grind
Water pump - stock; chromed
Cooling fan - Cooling Components 2,800 cfm
Radiator - Griffin aluminum
Alternator-polished aluminum
Heads - 2.02/1.6 camel hump
Valve covers - polished aluminum
Manifold / Induction - Weiand polished aluminum / Edelbrock 650-cfm
Ignition / Wires - HEI / Taylor
Headers - ceramic-coated block hugger
Exhaust / Mufflers - 2 1/4 / Borla stainless
TRANSMISSION
Year and make - '80 GM TH350
Shifter - Gennie
BODY
Body style / Material-pickup / steel
Body manufacturer - Dodge
Body mods - filled top; crank hole cover shaved from grille
Grille - filled grille shell, polished aluminum insert
Bed - handmade, Street Rods by Wildcard
Bodywork - Alex Gambino and Bill Osiakowski at Street Rods by Wildcard
Paint type / Color - RM Paint / custom-mix red
Painter - Alex Gambino, Street Rods by Wildcard
Pinstriping - Herb Martinez, Livermore, CA
Headlights / Taillights - Guide sealed beam, integral turn signals / '37 Ford
Outside mirror - Vintique, modified
Other body items - roll pan by Scott Cowen, stock door handles mounted upside down, plating by Superior Wheel and Bumper, San Jose, CA, lower door bottoms replaced, side splash aprons filled, rear fenders widened, Dodge emblem from Dodge Durango, retractable rear tag
INTERIOR
Dashboard - steel, stock
Insert / Gauges - stock, modified by United Speedometer
Wiring - Painless Performance
Steering wheel - Lecarra
Steering column - '87 Chevrolet Camaro
Seats - Glide Engineering bench
Upholsterer - Bill Osiakowski, Street Rods by Wildcard
Material / Color - leather and vinyl / Lexus Beige
Carpet-beige wool
