engine V8
position Front Longitudinal
valvetrain w/2-Stage Variable Intake
fuel feed FSI Direct Injection
displacement 4163 cc / 254.0 cu in
bore 84.5 mm / 3.33 in
stroke 92.8 mm / 3.65 in
power 313.2 kw / 420.0 bhp @ 7000 rpm
hp per litre 100.89 bhp per litre
bhp/weight 270.97 bhp per weight
torque 430 nm / 317.2 ft lbs @ 5500 rpm
redline 8250
drive wheels Quattro 4WD w/Torsen Centre Differential, DRC Dynamic Ride Control
body / frame Unit Steel
front brakes Cross-Drilled & Inner-Vented Discs w/ABS, ESP, EBD
f brake size 365 mm / 14.4 in
rear brakes Cross-Drilled & Inner-Vented Discs w/ABS, ESP, EBD
r brake size 324 mm / 12.8 in
front wheels F 45.7 x 20.3 cm / 18.0 x 8 in
rear wheels R 45.7 x 20.3 cm / 18 x 8 in
front tire size 235/40 R 18 Y
rear tire size 235/40 R 18 Y
steering Rack & Pinion w/Power Assist
f suspension Double Wishbones w/Anti-Roll Bar
r suspension Trapezoidal-Link w/Anti-Roll Bar
weight 1550 kg / 3417 lbs
wheelbase 2648 mm / 104.3 in
length 4586 mm / 180.6 in
width 1772 mm / 69.8 in
height 1397 mm / 55.0 in
transmission 6-Speed Manual or Tiptronic
gear ratios 3.667:1, 2.050:1, 1.462:1, 1.133:1, 0.919:1, 0.778:1
final drive 3.889:1
top speed 250 kph / 155.3 mph
0 - 60 mph 4.7 seconds
drag 0.3
Que lindo fierro, discreto, poderoso, y aparte me imagino lo que debe sonar ese V8 girando a mas de 8 lucas
