Re: Bielas de aluminio
Mas bien sipalqui. Sanpaoli asi boludo como lo ves le bailo sabroso a varios, este no seria el caso.
Para seguir, tema bulones que sipalqui arma con allen de ferreteria, mientras que BME...
Originally posted by meteorointerceptor
View Post
What About Cap Screws? BME Rods are assembled with two cap screws. Some racers call them "bolts" but, technically, that's a misnomer. A cap screw has a chamfered end, a washer face under the bolt head and its body dimensions are manufactured with tighter tolerances. A bolt has a flat end, no washer face under the head and has body dimensions made to less stringent specifications. A cap screw is installed and tightened by turning its head whereas a bolt is installed, then a nut is threaded on the other end and is used to tighten the fastener.
