Seguramente los vieron en algun lado, lo que me gusta de este modelo es que tiene una camara FLIR.
Technical Specification
Battery
Type
Non-removable Lithium Ion with Quick Charge 2.0
Capacity
3800mAh
Talk Time*
up to 30 hours*
Standby Time*
up to 43 days*
Display
Display Type
Super bright 4.7" a-Si AHVA, HD, 1280x720
Display Cover
Corning® Gorilla® Glass 4
Camera
Main/Rear
13MP Autofocus + FLIR Thermal Camera
Front
5MP
Video Capture
Yes, 1080p, 30fps
Connectivity
Audio Jack
3.5mm
Bluetooth®
4.1
NFC
Yes
Wi-Fi®
802.11 b/g/n
USB
micro-USB 2.0, USB-OTG
Sim Type
Nano sim (Single SIM)
GPS
GLONASS, GPS, aGPS, Beidou
Data Speed
Maximum Downlink Data Rate
150Mbps
Maximum Uplink Data Rate
50Mbps
Memory
ROM Flash
32GB
RAM
3GB
Extended Storage
microSD™ up to 128GB
Multimedia
Audio Playback
AAC, AAC+, eAAC+, AMR-NB, AMR-WB, MP3, MIDI, OGG, WAV, FLAC, MKV
Audio Recording
AMR-NB, AMR-WB, AAC, AAC+, eAAC, WAV
Video Playback
H.263, H.264, H.265, MPEG4, VP8, VP9
Video Recording
Network
2G
GSM/GPRS/EDGE
2G Frequencies
850/900/1800/1900 MHz
3G
WCDMA/UMTS/HSPA/HSPA+
3G Frequencies
850/900/2100 (ROW variant) | 850/AWS/1900 (North America variant)
4G
Yes, Cat 4
4G Bands (LTE)
1, 3, 7, 8, 20 (ROW variant) | 2, 4, 5, 7, 12, 17 (North America variant)
Processor
Processor Type
Qualcomm MSM8952-3 (4 x 1.5GHz + 4 x 1.2GHz)
Platform/OS
Android™ 6.0 Marshmallow
Rugged
IP Rating
IP68 Certified
Waterproof
Up to 5m for 60 mins
Dust Proof
Impervious to dust
Drop Test
Up to 1.8M (6 ft)
Military Standard
MIL-SPEC 810G, Shock and Drop, Operating Temp: -25°C (-13°F) to 55°C (131°F), Category 4 vibration
Sensors
Accelerometer
Yes
Proximity Sensor
Yes
Ambient Light Sensor
Yes
Compass
Yes
Size/Weight
Size
147.9 x 73.4 x 12.66 mm
Weight
223g
Destacado que lleve 8 nucleos, los 3GB de Ram y la capacidad de esa bateria, que sumado a una pantalla de 720 que no demanda tanto seguro va a dar buenos rendimientos de bateria.
Tema de precios algunos los prevenden en 15.000 lo mismo que cualquier Celular High end. Interesante que se pueda sumergir 2mts o 5mts mas la paliza que se puede aguantar
Fotos?
Quizas con suerte lo traen los operadoras.
Battery
Type
Capacity
3800mAh
Talk Time*
up to 30 hours*
Standby Time*
up to 43 days*
Display
Display Type
Display Cover
Camera
Main/Rear
Front
5MP
Video Capture
Yes, 1080p, 30fps
Connectivity
Audio Jack
3.5mm
Bluetooth®
4.1
NFC
Yes
Wi-Fi®
802.11 b/g/n
USB
Sim Type
GPS
Data Speed
150Mbps
50Mbps
Memory
ROM Flash
32GB
RAM
3GB
Extended Storage
Multimedia
Audio Playback
Audio Recording
Video Playback
Video Recording
Network
2G
GSM/GPRS/EDGE
2G Frequencies
3G
3G Frequencies
4G
Yes, Cat 4
4G Bands (LTE)
Processor
Processor Type
Platform/OS
Rugged
IP Rating
IP68 Certified
Waterproof
Dust Proof
Impervious to dust
Drop Test
Up to 1.8M (6 ft)
Military Standard
Sensors
Accelerometer
Yes
Proximity Sensor
Yes
Yes
Compass
Yes
Size/Weight
Size
Weight
223g
Fotos?
