Consumo de aceite fiat 500 . 0km !
    Re: Consumo de aceite fiat 500 . 0km !
    15 w 40 segun manual ? mamadera......
      Si los semi aca q te mandan fiat c el selenia creo q andaban ahi.
      Enviado desde mi SM-N900 mediante Tapatalk
          jajaja 15 w 40 .......
          algo sobre aceites del fiat 500 http://www.fiatforum.com/500/341305-...-oil-type.html
            jjjajajaja que HDP!! asi va a quedar la concesionaria de fiat
              pablo scr telefono jejejejjejej
                Otra temperatura ambiente es obvio que van a usar otro rango de aceite...
                  marco Baja presion de aceite o solo prendia el check por bajo nivel ?
                  me llama la atencion que la fabrica recomiende 15 w 40 que como mucho es semi sintetico -y no creo- cuando en el resto del mundo recomiendan el sintetico 5w 30 o 5 w 40
                  helpful.Report inappropriate content
                  poor reliability
                  by caveman11111111 from Texas | January 23, 2014
                  To get started, i bought this car on june 27th, 2012. It looked good and i thought i had a great car. I bought the pop with the manuel in it. On may 15th 2013 my car developed a electronic problem which told me to turn off the vehicle because of low oil pressure. The car was in the shop about 3 weeks. Seat belt retractor for driver also had to be replaced. I drove the car another 8500 miles and again the same thing happened. The dealer again told me the same thing. But unlike the last time, this time the shop replaced a number items in the engine. Camshaft, cylinder head gasket, intake manifold gasket, variable valve actuator assembly, etc. This was about another 3 weeks. That lasted about 2000 miles and now the same malfunction is happening again. This is the 3rd time and it is sure getting old. I have been told it may be in the shop this time for up to a month. Fiat only will give me a rental for 5 days I would have been better off buying an old used car that i can rebuild.
                    Gracias amigo , vamos esperar hasta el lunes haber que dicen del service.
                      el mundo gira sobre 5 w 30 o 5 w 40.....y ya ni eso, el Nuevo std es 0 w 20 y 0 w 30 por cuestion de consumo y porque las luces se fueron cerrando
                        Es una burrada que se rompan los aros por poner mas aceite?
                        se-r me exprese mal en realidad no quise ponerlo asi .. pero se supone que si tiene aceite de mas en lo que respecta al nivel tendria que quemarlo y tiraria humo por el escape .. o estoy equivocado??
                          Ja anda al sur argento o a Canadá... No todo es 5-30 5-40 y hay autos con mayor luz de fabrica también, sea Ferrari o porsche inclusive, más aún en Europa donde pasas de -10 a 45 grados.
                              poor reliability
                              creo que solo marco el check por nivel .. porque cuando se lo completo ya no marcaba mas el check-
                                Si semi sintético le consume y no ve la humareda, con sintético se lo fuma en 300 kms...
