un midget?
la agencia que decís vos diego 1.8 es de polaris?
sisisi esa !
Che bebu fijate que por el que preguntas vos tiene un motor estacionario, que con un embrague centrifugo para eje de 3/4 lo resolves... son motores de 160 a 500cc creo mono y bi ciloindricos refrigerados por aire, leva en la culata (o varillero llamalo como quieras), cuando los honda de 5,5hp se pusieron caros entraron los toyama a jugar fuerte. yo tengo uno, para un karting zafa, ta bueno. y para mostrar un funcionamiento basico de un 4T esta perfecto,
CHASSIS
Bronze welded 57mm, 38mm, 25mm dia. ERW /CDS steel tube
Aluminium bulkheads
Phosphated, powder coated finish
Right or left hand drive
SUSPENSION
Double unequal length TIG welded fabricated wishbones front and rear
Lightweight fabricated uprights front and rear
Outboard Bilstein dampers front and rear
Alloy steel Eibach coil springs front and rear
STEERING
Rack and pinion cast alloy steering rack 1.7 turns lock to lock
Collapsible offset steering column
Adjustable inboard joint and outboard rod ends
305mm race suede covered steering wheel
BRAKING
Front 240mm ventilated disc
Rear 240mm disc
Tilton aluminium racing pedal box
Twin master cylinders adjustable front/rear brake bias
WHEELS
Front 7Jx15
Rear 7Jx15
TYRES
Front 235/75R15
Rear 235/75R15
BODY
Non structural rotational moulded toughened polyethylene
Nose cone, engine cover, damper covers, mudguards
Composite screen, bonnet, engine access cover
SEATING
Twin seat unit composite woven cloth, 5 position adjustment
2" E Approved four point quick release full harnesses
INSTRUMENTS
LCD Digital display, speedometer and tachometer, water temperature, fuel level, odo, trip
Warning lights: Ignition, lights on, handbrake/low brake fluid low oil pressure, main beam, indicators, alarm
DIMENSIONS
Length 3215
Track 1585 front and rear
Height 1425
Wheelbase 2348
Width 1850
Approach angle 71 degrees
Departure angle 82 degrees
WEIGHT
670kg
ROAD PACK
Front/rear sidelights, projector headlamps, front/rear indicators, side repeaters, rear fog lamp, reverse lamp, number plate lamp. 3 way closed loop catalytic converter, front and rear mudguards, rear engine cover, road mirrors, parking brake, horn, electric fan
PERFORMANCE
0-60 mph 3.4 seconds (0-100kph)
Top speed 125 mp
