Que lindo para meter este 6 en un falcon o chevy (no son 6 tubos) FOTOS!!!
  • Que lindo para meter este 6 en un falcon o chevy (no son 6 tubos) FOTOS!!!
    Bueno boludeando en youtube encontre esto, que lindo seria meterlo en algun falcon o chevy (segun fanatismo obvio)
    De donde saque las fotos decia esto solo sobre el motor: Hi Guys, Thanks for your interest. The wheels are reallly quite light they are racing wheels so built lite. We are expecting around 800Hp atw. We are having a custom ecu made with enough drivers to run her.
    I couldn’t really care much about the Australia v NZ debate… if there was one though the Kiwi’s are definitely smashing us in the rotary department. 6 Rotor? Yeah… its happening!
    Pulse Performance Race Engineering (PPRE) are the boys that used to be responsible for Mad Mike’s Badbul before he went back to KiwiRE. This is the latest from them that is generating a lot of interest from around the world. PPRE6B Drag RX-4.
    There’s a fair bit of body work involved, which includes roll bars that were made to accommodate the stock dash… although they’re not sure it’ll fit. Would be very cool if it did though.
    Tubbed and tubed by PPRE. Apparently this is going to be run on the road as well the ‘zeroyon’… hence the reason why the original floor-pan was kept. Although they’ll need to get these certified, even the thought about running machines like this on the street is a pretty good incentive to go live in New Zealand…
    Hence the reason for the Tubs!
    Treaded tyres for the street, not sure if there is enough room in the cabin for the set required to come home from the corner store!
    Anyways what a crazy build! Gotta give it to PPRE for doing all the R&D and fabricating on this insane machine. We’ll keep you updated as much as we can!
    [YT]http://www.youtube.com/watch?v=Og2G4FkuL0w[/YT]
    [YT]http://www.youtube.com/watch?v=WA9V0roB82I[/YT]
    Respuesta: Que lindo para meter este 6 en un falcon o chevy (no son 6 tubos)
    nada mejor que despertar a los vecinos asi.....una maravilla....
      Mamama como suena eso por dios si soy el vecino me tenes paradito al lado del motor el pijama jajajaj babeado como Omero jajjaja.
      PD: que es un rotativo de 6 cilindros o 12?
        Un rotativo no lleva cilindros, tiene rotores
        Qué lindo para meter ese hermoso bichito en un Sport Prototipo o un Formula
          Vos te queres matar no?
          Dejame que yo sea tu piloto de prueba, prefiero sacrificarme yo
            ???? cilindros ??? , jajajaja , no no , es de 6 rotores , buscate mas info por youtube con el nombre de motor wenkel , ese motor no tiene cilindros , ni pistones , ni valvulas de escape o admicion , ni arbol de levas , etc. ...
              jajajajaja
              seeeeeeeeeeeeeeeeeee!!!
              piedras y botellas .... musica para mis oidos! XD
              ya estamos acostumbrados a eso! :P
                lo que es el rotativo la puta madre ......!
                pensar que cuando compre el alfa el willy tenia un 12A 0k ( segun el....)
                y de cagon no lo compre...........que boludo!
                  Pero moriría feliz
                    excelente !
                    que torque tienen esos motores ?
                    nah , es un v8 rotativo
                      dioooooooooossssssssssssssssssssss
                        Ufff lo que debe ir eso adentro de un scarlet made in puelto rico! Jajajajaj hacen los 400 en 3 segundo jajaja un sueño esos rotores!
                          jajajajajaa de unaa!!!
                            Re: Respuesta: Que lindo para meter este 6 en un falcon o chevy (no son 6 tubos)
                              Ahi agrege un par de fotoos!!
