SPECS
1992 Honda Civic Si
ENGINE
K24A3 2.4-litre in-line 4-cylinder i-VTEC
ENGINE MODIFICATIONS
K24A engine conversion, EGK1 Hasport engine mounts , lightened and welded Hasport mount brackets , Moroso breather can , CIrcuit Hero coil pack cover , K-tuned upper coolant housing , Hondata KPRO, Buddy Club N+ camshafts (intake: 298 degrees, 13mm lift; exhaust: 293 degrees, 12.5mm lift), K20A 50 degree VTC, Buddy Club valve springs , Buddyclub titanium retainers, K20A DC5R valve spring seats, Toda chain tensioner , Walbro GSS342 255lph fuel pump, Golden eagle fuel rail , Aeromotive Adj Fuel Pressure Regulator , Earls fittings with braided lines , Mugen fan switch, Koyo half-size aluminium radiator, Spoon Radiator Cap , JDMyard radiator stay , JDMyard intake manifold, 80mm Wilson throttle body, JDMyard 4-2-1 header, custom 3-inch stainless exhaust ,EP3 idle pulley kit , K20A2 Crank pulley , Earls 19 row oil cooler , Earls sandwich plate , Swappable Burns stainless megaphone w/ reverse cone exhaust and 200mm Velocity stack for drag racing use
DRIVELINE
Y2M3 K20A (DC5 Type R) six-speed gearbox, 4.7 final drive - LSD, Exedy 3-puck racing clutch, EP3 flywheel, K20A DC5 Type R driveshafts and midshaft , Rcrew shifter mount plate with raised up extender , DC5R shifter box , DC5R shifter cable with corsport shifter bushing.
SUSPENSION & BRAKES
Tein Super Racing coilovers - external reservoir (22k front spring rate , 14k rear spring rate), Function 7 rear lower control arms, Full Race traction bar , ASR subframe brace , DC2R front and rear sway bar kit, 282mm slotted front brake rotors, Ferodo DS2500 front pads , NSX front caliper , 260mm slotted rear brake rotors , DC2R rear caliper , OEM rear pads , APP braided brake lines , 1-inch DC2R master cylinder and brake booster , Hardrace Front and rear camber kit , Hardrace Roll Centre Adjuster ,Whiteline Caster kit. Spherical bearing rear trailing arm bushings , Spoon and mugen bushings.
WHEELS & TYRES
13x8-inch Weld Racing front wheels, 15x3.5-inch Bogart rear wheels, Mickey Thompson 24.5x9x13 front and 24x4.5x15 rear tyres
15x9 +36 949 Racing wheels with 10mm spacer on the front (extended studs) . 15x8 +36 949 Racing wheels with 3mm spacer on the rear.
225/50/15 Yokohama AO48 , 225/45/15 Hankook z214.
INTERIOR
Stripped interior, removed sound deadening, Bride Zeta 3 fixed seat , Bride seat rail ( ightened) , Bride retrimmed door cards , Takata 4 point harness , Nardi Deep Corn steering wheel w/ blue stitching, HKB 80mm long boss kit , Defi tachometer with custom surround to OEM cluster, Defi Shift light , Defi link meter , Defi link control unit 2 , Mugen shift knob, JDM OEM single-DIN block-off plate , Bonds Roll cage with harness bar , JDMyard ECU tray.
EXTERIOR
J's Racing Front lip , EG6 rear wing with J's Racing GT wing , Custom Wide Front Fender , OEM Honda Antenna block off plate , Spoon Cf Bonnet , Sparco Bonnet pins , EG6 plastic headlights , Vision Type DC side mirrors , Rear wiper delete kit , Custom Battleship grey paint.
