Honda CRX - JDM
  • Honda CRX - JDM
    Propulsion:
    K20Z1 engineRSX Type S transmissionHasport EFK1 engine mountsWeb Cam AS2 camshaftsSupertech valvespringsSupertech retainersVibrant 3-inch intake pipingK&N air filterDC Sports headerCamino Mufflers 3-inch pipingVibrant race mufflerWalbro 255-lph fuel pumpGolden Eagle Pro Series fuel railRussell Pro-Classic lines and fittingsTrick Flow fuel filterAeromotive fuel regulatorFull-Race Pro Street radiatorSamcoSport radiator hosesPassword:JDM Kevlar plug coverPassword:JDM hood dampersKarcepts accessory relocation kitKarcepts shifter kitKaiten 9-pound flywheelQuaife limited-slip differentialDrive Shaft Shop 2.9 axlesHondata K-Pro ECU
    Stance:
    Ksport Kontrol Pro coiloversNext Miracle X-barBenen rear lower tie-barETD Racing/K-tuned traction barSkunk2 rear lower control armsPowdercoated suspension arms
    Resistance:
    Brembo rotorsPBR ultimate ceramic brake padsATE Super Blue brake fluidEarl's steel-braided brake linesChaseBays AN hard-line brake linesRelocated proportioning valve
    Rims & Rubber
    15x7 Enkei J-Speed III (+35 offset)195/50-15 Yokohama S.Drive
    Outside:
    JDM EF8 front endJDM EF8 doorsJDM EF8 mirror block-offsJDM EF8 window visorsLexus SC430 Egyptian Sand Metallic paintSmoked taillightsSmoked bumper lights
    Inside:
    Status Racing "The Ring" Kevlar bucket seatsNagisa Auto's EF8 seat railsNardi Sport Rally 350mm steering wheelEF8 gauge clusterPassword:JDM Kevlar fuel-pump coverChaseBays shift knobChaseBays military-spec engine harnessMemphis Audio 6.5-inch front speakers
    Nota Completa = http://www.hondatuningmagazine.com/f..._hf/index.html
    Respuesta: Honda CRX - JDM
    que fanta le escondio los cables....
      me encanta este Honda !
        Yes!
        specs?
          Originally posted by eze-jdm View Post
          Yes!
          specs?
          lito!.. fijate arriba..
            Ahora si
              Que lindos son los CRX, LPM, son kartings.
              No comparto mucho el color champagne.
                mmm.. no es jdm puro...
                3..2...1... boom!!!
                Muy lindo!!
                  POR Q NO TENGO PLATAAAAA
                  Honda Crx - $ 16.000,00 en MercadoLibre
                    Originally posted by NiSmO View Post
                    prefiero esta Honda Crx Coupe Roja 1991 - $ 30.000,00 en MercadoLibre
                    a esa q vos pusiste q esta prendida fuego...
                      esta muy linda la roja pero por esa plata te compras algun bm ochentoso bien parado
                        Bellicima la crx, las llantas espectaculares...
                          que laburo que tiene esa crx por favooor!! , me encanto por todo lados!!
                            Es JDM Pura?
                              Originally posted by Turbinator View Post
                              Es JDM Pura?
                              nap
