’96 Civic EK9
Propulsion
K24
Toda 50mm individual throttle bodies
Drag Cartel Stage 4 cams
Blox Racing header
R Crew cat-back exhaust
AQ Motorsports hi-flow cat
Portflow headwork
Supertech valves
Supertech valvesprings
CP 11.5:1 pistons
Carrillo rods
K-Tuned fuel rail
Walbro 255 lph fuel pump
RC 750cc injectors
AEM FPR
HaSport motor mounts
Gear-X close gearset
Hybrid Racing shift box and cables
ACT clutch
ACT flywheel
Wave track differential
HaSport axles
Rywire radiator
Hybrid Racing hoses
Rywire mil-spec engine harness
AEM ECU
Power
300 whp on 91 octane
Stance
JRZ RS two-way coilovers
Hyperco springs
ASR adjustable rear antisway bar
DC2 front antiroll bar
Hard Race spherical bushings
Hard Race alignment kit
Spoon Sports shock tower bar, front and rear
Resistance
StopTech two-piece rotor, front
Spoon Sports caliper
Hawk DTC
Motul DOT 5 fluid
StopTech brake lines
Wheels and Tires
949 Racing 15x9 +40 front
949 Racing 15x8 +40 rear
Nitto NT01 225/50-15
Exterior
Hudson Auto Body paint and body
Spoon Sports carbon-fiber hood
Spoon Sports carbon-fiber mirrors
Special Projects front lip and splitter
Seeker rear wing
Alex wing risers
Interior
Recaro Pole Position buckets
Sparco 6-pt harness
Personal steering wheel
Spoon Sports gauge cluster
Spoon Sports shift knob
Auto Power 4-pt bolt-in
GReddy 60mm oil pressure/temperature gauges
Propulsion
K24
Blox Racing header
Portflow headwork
Supertech valves
CP 11.5:1 pistons
Carrillo rods
K-Tuned fuel rail
RC 750cc injectors
AEM FPR
ACT clutch
ACT flywheel
HaSport axles
Rywire radiator
Hybrid Racing hoses
AEM ECU
Power
Stance
Hyperco springs
Resistance
Hawk DTC
Motul DOT 5 fluid
Wheels and Tires
Exterior
Seeker rear wing
Alex wing risers
Interior
Sparco 6-pt harness
’01 S2000
Propulsion
F22 stroked to 2.4L
BC crankshaft
CP 9:1 pistons
Carrillo rods
Assembled by Laskey Racing
Portflow headwork
Supertech valves
K20A OEM retainers
Toda cam gears
Garrett GT3076 turbo
AQ Motorsports 4-inch intake
AQ Motorsports turbo piping
AFI intake manifold
AFI Novak-spec turbo manifold
TiAL V-band turbo exhaust 103 housing
Swain Tech coating
Blox 70mm throttle body
AQ Motorsports side exit exhaust
TiAL blow-off valve
TiAL 44mm wastegate
GReddy intercooler
Koyo radiator
AQ Motorsports custom V-mount
Hosetech couplers
Earl’s AN fittings and quick-disconnect hoses
Trust oil cooler
Moroso oil accumulator
Detchwork 1,600cc injectors
Earl’s fuel filter
AEM FPR
ACT six-puck clutch
Toda flywheel
Driveshaft Shop custom 4-inch driveshaft
Driveshaft Shop–modified Porsche axles/adapters
AEM ECU
Defi sensors
Power
520 whp on E85
Stance
Hyperco springs
J’s Racing front bumpsteer kit
J’s Racing rear trailing arms
J’s Racing roll center adjusters, front and rear
ASM under-body brace
Cusco front subframe brace
Resistance
One-of-a-kind brake system
StopTech 15-inch two-piece rotor, front
StopTech 13-inch two-piece rotor, rear
StopTech six-piston caliper, front
StopTech four-piston caliper, rear
Motul DOT 5 fluid
Wheel and Tire
Enkei NT01 18x10.5 +30
Toyo R888 295/30-18 front
Toyo R888 315/30-18 rear
Exterior
Amuse GT1 wide-body kit
J’s Racing carbon-fiber hood
ASM dry carbon trunk
ASM dry carbon duckbill spoiler
Mugen FRP hardtop
Kognition Design dry carbon GT wing
JDM headlights
Password:JDM Kevlar under diffuser
Craft Square carbon-fiber mirrors
Interior
Bride Zeta III Type L
Custom seat brackets
MOMO boss
ASM shift boot
NASA-spec rollcage
JC Meynets pit clock
AiM MXL dash
Propulsion
F22 stroked to 2.4L
BC crankshaft
CP 9:1 pistons
Carrillo rods
Portflow headwork
Supertech valves
K20A OEM retainers
Toda cam gears
AFI intake manifold
Swain Tech coating
TiAL blow-off valve
TiAL 44mm wastegate
GReddy intercooler
Koyo radiator
Hosetech couplers
Trust oil cooler
Earl’s fuel filter
AEM FPR
ACT six-puck clutch
Toda flywheel
AEM ECU
Defi sensors
Power
520 whp on E85
Stance
Hyperco springs
Resistance
Motul DOT 5 fluid
Wheel and Tire
Exterior
Mugen FRP hardtop
JDM headlights
Interior
MOMO boss
ASM shift boot
NASA-spec rollcage
AiM MXL dash
