Mr. Wangan!!! "NISSAN SKYLINE R34 V-SPEC NUR 02" No apto para cardiacos!!!
  • Mr. Wangan!!! "NISSAN SKYLINE R34 V-SPEC NUR 02" No apto para cardiacos!!!
    Power 800hp/615lb-ft at 1.6-bar boost
    Engine
    N1 Nür engine block; Trust extended baffle, stainless exhaust manifold, Type-C external wastegate, T88-33D turbo, intercooler and oil cooler with oil filter relocation kit; HKS Step 2 2.8L kit (forged pistons, H-section conrods, balanced crank), HKS 1.2 mm metal head gasket, V-Cam Pro (intake), 272° camshaft (exhaust), valve springs, oil pump, hard pipe kit, SPF foam filter and Twin Power Type-DLI II; Auto Select ported and polished head, 90mm front pipe, full titanium exhaust system, aluminum intake pipe, carbon radiator shroud, oil catch tank and collector tank; Bosch external fuel pump; SARD FPR and 1000cc injectors; GReddy billet fuel rail; ARC side-flow radiator with air separator tank
    Drivetrain
    Exedy triple-plate carbon clutch and lightweight flywheel; ARC transmission cooler
    Engine Management
    HKS F-Con V Pro ECU, EVC boost controller and fuel-mixture controller
    Footwork & Chassis
    Auto Select adjustable suspension kit with 20 kg/mm springs front & 22 kg/mm rear, billet front strut tower bar; front/rear Ikeya formula pillow-ball adjustable arms; ARC anti-sway bars
    Brakes
    Brembo 8-pot front calipers with 380mm Rdd 2-piece slotted discs, Brembo 2-pot stock calipers with larger offset kit and 355mm Rdd 2-piece slotted discs
    Wheels & Tires
    Volk Racing TE37 10.5Jx18", Hankook Ventus TD 295/30 R18
    Exterior
    Auto Select “Nismo Version 1-style” front bumper, Auto Select carbon-fiber front lip spoiler, diffuser and carbon Kevlar wing stays/spoiler end caps/rear wing flap; Sun Line Racing carbon-fiber hood; NISMO Z-tune front fenders, front & side clear repeaters, side skirts, rear skirts, rear fender finishers and rear GT LED lights
    Interior
    Auto Select carbon-Kevlar bucket driver seat, steering wheel and removable hub; NISMO 320 km/h combination meter; A’PEXi ASM speed meter; GReddy gauges; Field E-TS controller
    Respuesta: Mr. Wangan!!! "NISSAN SKYLINE R34 V-SPEC NUR 02" No apto para cardiacos!!!
    BRUTAL. Solo eso...
      Pero que bueno que esta!!!
        Da miedo ese monstruo. Y blanco me gusta todavía más!
          uffff :|
          tan lejos se ve...
            letallllllllll
              Terriblee !! muchisima violencia
                siempre con autos chotos vos
                  Brutal y discreto :)
                    se arrastra.........
                    que soplete.
                      ME encanta! muy violento yyyy muchoo estilo! jeje
                        Naa la puta madre que auto!!!!
